Peripherals Headset Questions
Discussion in 'Hardware' started by Ream, 8 May 2011.
  1. Ream
    Ream What's a Dremel?
    17 Nov 2010
    Hi, I thought i would use the knowledge of of the Bit-tech forums for my own needs. I have a few questions about headsets. as I am after a new set for around £65.
    So are 5.1 sets just a gimmick? or would i be better off with a regular headset? or a new soundcard and headset?
    I currently use a cheap set of creatives and onboard sound, this is for 95% gaming and 5% video watching and editing.
    thanks in advance.
    I have been looking at the Roccat Kave 5.1 and the Corsair HS1a with a Asus xonar DG 5.1 card both about the same price.
  2. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    http://www.bit-tech.net/hardware/peripherals/
    I believe Bit-Tech's top ones for your price range would be the Corsair HS1A and the Razer Carcharias.
    The HS1A comes with 3.5mm jack so you would still be using the integrated sound on your mobo, however, if you wanted ones with a built in external sound card, the HS1s connect through USB.
    The Carcharias connects through 3.5mm jacks aswel.
  3. Kakeshoma
    Kakeshoma What's a Dremel?
    11 Jan 2011
    I strongly recommend Corsair HS1.
    Ive used tons of sets, last was Roccat Kave with Xonar D2X sound card, the HS1 is by far the most comfortable of them all, and the sound is just excellent. 50mm drivers makes a huge difference over other sets.
  4. Strudul
    Strudul ~
    31 May 2010
    I would not say 5.1 is a gimmick at all.
    Especially for gaming. I am guessing you want to use them to soundwhore (hear where everyone and everything is). I have tried varies stereo and 5.1 heasets and 5.1 gives you a much better idea of where people are and what is going on.
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    5.1 is a complete gimmick.. As are gaming headsets in general.
    You'll get that same surround effect on a pair of stereo headphones with Dolby Surround (or similar) through your sound card, and you won't have to deal with the awful sound quality that you get with the several small speakers crammed into that casing.
    Gaming headsets tend to break quickly, are made of crappy materials, and sound woeful compared to good similarly priced headphones. Anyone who says otherwise either hasn't experienced a proper stereo headphone setup, or is sponsored by a headset manufacturer..
    Find me someone that says "yeah those Audio Technica AD700s really weren't good for gaming, I'm so glad that I bought the Logitech/Razer/Corsair/Tritton/Turtle Beach/whatever set!" and I'll reconsider, but pretty much all success stories with headset buying go more like this: "My gaming headset broke after six months/has been held together with tape and rubber bands for a year, what should I buy? Oh? Real headphones you say? Wow, this is much better!"
    I could link you to several threads on here that went exactly like this.
    My belief is that a real pair of headphones is the best option, for every budget.
    For your budget, the best option IMO is a JVC HA-RX700 (~£30) + the Xonar DG (~<£30) + a desktop or clip-on mic (£5-10?).
  6. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    I strongly recommend the Senheisser 166 USB (even hase built in soundcard, which u can bypass if you have a good sound card), Been using it now for 3 years and the sound is great also people can understand me better then most headsets/phones. (I use skype for calling)
    the only niggle is it is the on ear cups instead of over the ear.
  7. Strudul
    Strudul ~
    31 May 2010
    5.1 headsets and gaming headsets do not break easily.... I have had mine (sharkoon xtatics) for a good year and they are in perfect condition. The reason they break is because they are not treated very well.
    I agree that for music, a good stereo headset will give much better quality, but for gaming I still believe a decent 5.1 headset is the way to go.
  8. Sexton
    Sexton Minimodder
    2 Jun 2010
    Using the Roccat Kave's myself - bloody brilliant headset. I was reluctant to buy them at first after reading Custom PC's review on them, but they couldn't be far off. The sound quality, bass, and true 5.1 are just fantastic. Built like a brick shithouse as well being German :)
  9. Pete J
    Pete J Employed scum
    28 Sep 2009
    Definitely agree. Better to get a high quality stereo head set.
  10. Sexton
    Sexton Minimodder
    2 Jun 2010
    Everyone told me that before I bought my Roccat's... couldn't be further wrong. I had a pair of Creative Fatal1ty's before these with CMSS 3D on, and it was very good yes, but is nothing in comparison to true 5.1.
  11. Jipa
    5 Feb 2004
    HS1's are damn comfortable and sound clear as anything, but they do lack on bass. If this doesn't bother you, or if you're OK with simply EQing a bit more, go for it.
    Otherwise I'd suggest just some regular stereo headphones and a separate microphone. Definitely skip the surround malarkey, I'm yet to find a proper set, let alone at that budget...
  12. Cei
    Cei pew pew pew
    22 Mar 2008
    What external mic would people recommend? I've already got a nice set of Sennheiser headphones, so need a mic that won't sound like ass on voice comms, but equally not an insane price.
  13. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    I agree 100% with ^^
    I also own a pair of sharkoon xtatics, previously played with a decent set of sony stereo cans, and bugger me they dont compare, music indeed is not what they are there for, but using the spdif with the xtatics is amazing, you can even adjust each speaker's level independantly. I've never been so good at BC2! I'm so glad i paid the extra buck for these
  14. docodine
    10 Feb 2007
    I use a Logitech desktop mic that I bought for $8, never get complaints about voice quality. Just don't boost the gain too much and watch your volume, and a cheap mic will do.
  15. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    while more expensive the snowball microphone is surprisingly good sound quality, near studio. its also nice looking kind of like an old school radio announcer look.
    as for the op, i also agree that spending the money on standard stereo headphones is a better choice, if you want one with an integrated mic you could look for ones geared towards dj's or recording studio use. even the bargain ones in these categories have much better sound range and build quality than most gamer phones. even my frends headphones i originally got for my ipod sound better than the razer carcharias my mate has.
