A/V Headset Stuff
Discussion in 'Hardware' started by mikeyandrewb, 24 Dec 2011.
  1. mikeyandrewb
    mikeyandrewb What's a Dremel?
    31 Oct 2011
    Hi, I want to add a headset to my rig if possible.
    Don't scream and say I should get set of headphones and a separate mic, this is probably the best option, but not the one I want.
    I was looking at either the:
    Corsair Vengeance 1500 USB
    or
    Corsair Vengeance 1300 + Asus Xonar DS
    or
    Somthing like this, that is better :D
    Also does the Xonar DS require an extra power connector or does it draw all it needs from the PCI slot.
    Thanks :clap:
    and Merry Christmas
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
    I can't comment on the corsair headsets, but the Xonar DS is cracking bit of kit. It also draws all it's power from the PCI slot.
  3. mikeyandrewb
    31 Oct 2011
    Ok thanks Kernel!
