Cooling Heatsink to try and hit 4Ghz
Discussion in 'Hardware' started by gilljoy, 25 Aug 2011.
  1. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Looking to see If i can get my i7 930 to try and hit 4GHZ stable for a 24/7 clock.
    Currently got the bog standard intel piece of **** stock cooler. So obviously need something else to try and start over clocking.
    Just wondering what cooler people would recommend for about £40-50. I was looking at an AIO cooler but I'm not sure if there worth the price.
    Kinda wishing I waited until sandybridge was out... the heat these 1366's put out is mad
  2. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Noctua NH-D14. I use it coupled with 2 x Scythe GT1850's and I'm running 4.1GHz on a Core i7 920. 27 degrees idle, 56 degrees load. Sat in a Silverstone FT02B-WRI.
    I have pics if you'd like to see the setup.
  3. balatro2005
    balatro2005 Minimodder
    19 Sep 2009
    If it will fit your case you could try a Corsair H50 CPU cooler theres one on the market place for £38 http://forums.bit-tech.net/showthread.php?t=213748. At 4Ghz I think you should be looking at water cooling as an option.
    Other wise I think one of the better coolers is a Be Quiet! Dark Rock Advanced. Can't say from experience as I switch to water cooling due to the heat I was getting at 4Ghz.
  4. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    You don't need anything special for 4GHz - I could do it with my Xigmatek Dark Knight which cost me £20, and my CPU runs especially hot for an i7, maybe even more than yours. The only reason I upgraded to a Thermalright Ultra 120 Extreme was because I wanted 4.2GHz stable, which I got, and higher if needs be.
    I'd suggest getting a TRUE since they are still very good and only about £35-40 for 1366; I got a Delta PWM fan from ebay for £5 and it's better than any of the £15-20 pieces of utter crap in the "high end" fan market. You could get a cheaper cooler which already has fans, but it likely won't be as good (which I found with the Xigmatek DK)...but then again all you want is 4GHz. :)
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    My mate uses a H50 and his 920 happily runs at 4GHz :)
  6. Parge
    16 Jul 2010
    Do you know what stepping his CPU is, and what temps he gets?
    I have a 920 D0 stepping and a Kuhler 620 and was aiming for the same.
    Gilljoy I'll post my temps up over the weekend and let you know what its like.
  7. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Thank you man I'd really appreciate it
