Modding heatsinks and a case
Discussion in 'Modding' started by f U z ! o N, 31 Oct 2004.
  1. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    just a quick question. i have been pondering this idea for a while. would attaching heatsinks to a case's insides help dissipate the heat to the metal. now, before you start to flame away actually think about it for a bit. the heat from the inside of the case would be transferred to the heatsinks im assuming making the case a conductor for the heat. what do you guys think?
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    well i tought about it for a hour. anyway you would be spreading the heat out onto more space but i dont think the case conducts enough heat to even make a difference. Good idea tho
  3. f U z ! o N
    1 Feb 2004
    it would still look pretty badass
  4. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    how would it look badass... and how would it be done? there are already heatpipe cases that use passive cooling (*cough* zalman) and are nearly silent (hd and cdrom grinding aside)...
    Steel isn't that great of a material to help cool off... to be truely efficient it has to be aluminum that will conduct and dissipate well (read: thick, channeled aluminum)... this wouldn't be an easy task to pull off and get positive results.
  5. f U z ! o N
    1 Feb 2004
    yeah i kind of realize its a dumb idea but what do you expect at 1 am in the morning! lol. seriosuly it was just a spur of the moment idea.
  6. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    less than two hours later...
    contradictory of statements? its 2:30 in the morning here, and i cought that. dont mean to be bitchy, just thought that was interesting... :eyebrow:
  7. Ben '71 1200
    Ben '71 1200 What's a Dremel?
    16 Aug 2004
    I'd imagine any gains would be lost when you funk up the airflow with great big lumps of metal...
  8. f U z ! o N
    1 Feb 2004
    yah seems i did kinda contradict myself lol. sorry.i deserve to be flamed for this so flame away :rock:
  9. f U z ! o N
    1 Feb 2004
    i guess the reason i asked this was because one of the recent max pc mags was talking about the st. anger mod (there is thread below mine on this) that used 2 tecs and it said he connected them to the case making it one big heatsink. of course they did not show pics of the tecs.
  10. Ham_fisT
    Ham_fisT What's a Dremel?
    15 Aug 2004
    Actually, this is not a bad idea. look at what Zalman has done with this very concept!
    http://www.frozencpu.com/cgi-bin/frozencpu/cas-208.html
    the entire case is One HUGE heatsink, with heatpipe technology throughout.
    although implementing this with an ordinary case would be difficult, I think.
  11. Zephyr
    1 Oct 2004
    ive spent awhile looking at the Zalman case before, and it seems almost overdone to me. the concept is good, but i think they overused the idea, and overpriced it. by combining heatpipe technology and some really really good heatsinks, along with a good heat-conductive case, you could do something pretty cool by piping the heat from key heat-generating components (i.e. cpu, gpu, north&southbridge, possibly RAM) to extremely high-quality heatsinks incorporated to a very conductive case (such as a nice, thick but channeled aluminum case) you could spread the heat out nicely. of course, i imagine grounding would be an issue, not to mention the fact that the heat would then dissapate into whatever room this rig was in, effectively turning your office into a dry-sauna. it seems easier just to get a decent watercooling kit :rock:
  12. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    i wondered about the ST Anger thing too, but one thing i do feel is that there's little point in chilling the outside of the case. After all the huge passive innovtek rad on the side just heats it back up again... can anybody find the modder responsible for that case and ask him for pictures?
