hehe wanting a good screen
Discussion in 'Hardware' started by Burnout21, 30 Apr 2007.
  1. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    hey there guys as the title says i want a screen with a res of 1600x1200, i dont know why newer screens have a res of 1680x1050?
    got to be 20'' plus but not to pricey, looking at the £200 mark no more than £250.
    any ideas, i know there use to be TFT's with 1600x1200 but dam'd if i can find them!!
    oh and DVI is a must, but HDMI is a waste for me i dont mind it but i wont pay extra for it.
    my plan is to run it as primary screen and have my current 17'' tft as a secondary, which will display toolbars for 3DS max and photoshop CS2. plus winamp and MSN when im bored! lol!
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
  3. beesbees
    beesbees What's a Dremel?
    29 Apr 2007
    Can't be sure of the retailer's reliability, but I was loooking around for one a few weeks ago and came across this: http://www.europc.co.uk/pages/ProductPage.aspx?PID=68885
    Dunno if that's any good to you :)
    Actualkly WTF? in the description it says 1600 x 1200, but in the specs it says 1450 x 1050 :confused:
  4. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    they are 1600*1050 because they are widescreen. the widescreen 'equivalent' to a 1600x1200 4:3 display is a 1920x1200 24" display.
    you can get 20" 4:3 panels, although they tend to be more pro oriented and quite expensive.
  5. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    You gonna be overclocking it then :idea:
    :D
  6. Burnout21
    9 Sep 2005
    ok you lost me........
    screen size is important to me, i need to be able to display 3D models nice and big makes life so easy. If any of you guys used solidworks you must understand how important screenage is! lol!
  7. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    I hear you on the screen size in solidworks..Basically anything CAD related need a big screen.. and a Quadro card :D
  8. Burnout21
    9 Sep 2005
    quadro's are just the same as gaming card by nvidia, just improved memory (believe its shielded) and better driver surport.
    my 8800GTS is eatting everything in its path at the moment. so is a 22'' good value at the moment?
  9. Fod
    26 Aug 2004
    for a workstation, maybe. but if you're operating any kind of realtime, multi display environment you need a quadro card for the genlocking hardware it has.
    they are also more powerful :)
  10. DougEdey
    5 Jul 2005
    If you really need screen space save up for a full 16:10 24" job. Myself and Hazardous both made the jump (seperately I must add) and I don't think I'll ever willing go to a smaller screen.
    I run on a 17" at work, but I can't get a bigger one because I'm only here till July.
  11. Burnout21
    9 Sep 2005
    can you recomend a current screen of that type? what kind of money will that cost?
  12. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I run Solidworks on 2 30" screens, using 2 8800GTXs. It's heaven.
    I'm going to be building a workstation soon (FX5600, 2 quad xeons, 16GB mem) Not for me unfortunately, but I will get to play with it a little before sending..
  13. Burnout21
    9 Sep 2005
    that would be great, but my wallet cried!!!!
  14. Burnout21
    9 Sep 2005
    ok i seem to remember a screen that had a switch where the inputs could be flicked between.
    think it was a Dell, basically it has dual input, Anolog and Digital inputs and they can be switched, so two computers could be used on one screen with just a KVM to switch mouse and keyboard.
    that would be ideal for me!
  15. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    My 2005FPW does that. The 24" one does too.
  16. Burnout21
    9 Sep 2005
    thank you, guess i will go for a Dell 2005FPW as there not that expensive and a nice size screen.
    the older Dell 2001FP has a res of 1600x1200, dose this screen also have the same function i am after?
  17. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    tbh i would love to see the dells etc have a small kvm built into them, would be awesome
  18. heir flick
    heir flick Minimodder
    2 Feb 2007
  19. Austin
    Austin Minimodder
    16 Jul 2004
    :worried: I would suggest going for a 16.7Million colour screen, the 16.2Million are a rip-off and actually have 262Thousand actual colours and poor viewing angles too. '16.2M' hasn't been a worthwhile trade-off for ages, pixel response times are easily fine now even on budget screens. 80% of screens being sold are the 16.2M rip-off type, so beware. Brightness, contrast and response are all good now so I wouldn't worry too much about those when choosing your screen. Why use gfx cards and video streams which work in 16.7M with a screen that's limited to 262T?
  20. Boxcarhobo
    Boxcarhobo What's a Dremel?
    12 Sep 2006
    Viewsonic VX2025 from scan.co.uk
    best 20" screen
