Right , does anybody on here know about sound systems ? Basically I want to know if this lot will actually work if I get hold of it? My only uncertainty is can the amp power the speaker ? Am I right in thinking that its 'not' wattage that counts it's how sensitive the speaker is? And will the battery suffice ? And for how long? I'm trying to make this system as efficient as possible . If anybody knows about this kind of stuff or can advise me that will be awesome !!! http://www.ebay.co.uk/itm/TOPPING-T..._HomeAudioHiFi_Amplifiers&hash=item2a368824f4 http://www.ebay.co.uk/itm/Lucas-12V...rElectronics_Batteries_SM&hash=item4ac66f82d6 http://www.gear4music.com/PA-DJ-and...ord__match__&gclid=CL_ix7uwxb0CFZDKtAodglYAmA
What is your objective? Budget? Usage enviroment? It would be much easier to use a few minirigs and a minirig bass look on amazon.co.uk Sent from Bittech Android app
Hi mate, My objective is to strap it onto a Raleigh shopper and use it as a portable system to take to parks and such. My budget is as cheap as possible for a good sound ! I,m just looking for somebody to tell me that all the components will work together and that the battery is good enough for a good 8 hours.
