Build Advice Help Building a computer
Discussion in 'Hardware' started by samozamo, 19 Jul 2010.
  1. samozamo
    samozamo What's a Dremel?
    19 Jul 2010
    My old pc recently died on me for no real reason. (I moved my bedroom around and when I plugged it all back in and tried to use it, it just would connect to my monitor and just doesnt seem to turn on properly.)
    But now I have decided to get a new one and I want to build one. The only problem is I don't have a huge buget (maybe £400 - £500, closer to £400 the better). If it's not possible, I was looking at the computer to just buy (link below). But wasn't sure if that's the best for the money.
    http://www.ebuyer.com/product/186618
    Budget:
    £400 - £500 (Closer to £400 the better).
    Main uses of intended build:
    Casual gaming (The Sims, Civilization, some RTS's, etc...)
    Web browsing
    Watching films and Tv show
    Music
    Parts required:
    Everything, but if I can use the OS from my previous computer some how, I wouldn't mind doing that until a later date, so I could spend more on other parts.
    Monitor resolution:
    Would be using my old monitor for now, that is 17inch's, can't recall the resolution. But will be looking to in the future buy a 20-22inch monitor. (Will be using old monitor for now to save money for other parts.)
    Storage requirements:
    500GB will be more than enough.
    will you be overclocking:
    No
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers):
    Onboard sound.
    Extra information about desired system:
    Will want to upgrade in the future.
  2. danielleil
    danielleil Can't stop spending...
    20 Aug 2009
  3. danielleil
    20 Aug 2009
    As for the compaq, I'd be mad if I found it! There's a lot of satisfaction to be had by building your own.
  4. samozamo
    19 Jul 2010
    Thank you
    Thank you for your reply, well the two of them :).
    I was just wondering, is necessary to spend £120 on a graphics card?
    Plus what do you mean you'd be mad? Should I stay clear from Compaqs?
  5. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    No you don't have to do anything you don't want to :)
    It depends on what you want to do with the pc. Do you intend to play games? If so, which ones and on what size of screen?
    If you are not a gamer then there are Much cheaper options.
  6. samozamo
    19 Jul 2010
    Tbh I've never been a big pc gamer, but thats mostly down to never having a decent pc. I've always relied on the ones my parents have got (I'm 18 btw). But games I would mostly be likely to play games such as The Sims, Civilization, etc.
    As for the monitor I would be using the old monitor thats a mere 17inchs I think, but I'll be looking to get a 20-22inch monitor when I have the computer.
    Any views on this card?
    http://www.ebuyer.com/product/189621
    Oh and thank you for your reply :D
  7. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    That card will struggle with a 1680x1050 on even old games.
  8. samozamo
    19 Jul 2010
    Oh really? Good thing I brought it up then :)
    I'm not great at this, how can I tell how good a graphics card is?
  9. murraynt
    murraynt Modder
    6 Jun 2009
    The only way is to read review as they they so much.
    On paper one might be better than another but that might not be the truth if you want to play game with excellent graphics you will be looking at an Nvidia 460 GTX.
    But a 5770 will be ok as long as you don't want everything turned up to the max
  10. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    There's no foolproof way to tell from just the numbers so you can only really rely on benchmarks. I personally use the Tom's Hardware chart (here) quite a lot as it's reliable & has a wide variety of tested cards.
    I'd go for either the ATI 5770 or save some money & get an older generation ATI 4850/4870/Nvidia GTS 250 depending on whichever you find cheapest.
  11. roosauce
    12 Feb 2010
    There are two recent threads on this forum about best graphics cards for under £150 and under £100.
    There's a lot if posts but hopefully it will give you some ideas.
  12. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Although such a restrictive budget does help focus our advice, it'd still be best if we knew exactly what you were planning on using this thing for. Could you start here, if you get a moment?
  13. Publ!c Enemy
    Publ!c Enemy or Richard for short
    4 Jul 2010
    Do you think that you would do more PC gaming if you had a more powerful computer, i know i did when i got a better one. Last thing, have you bought the CPC mag thats out now? because it has a sub £400 system in it and they go through how to build and what to do. :)
  14. Parge
    16 Jul 2010
    Hey mate!
    Lots of info I know.
    You have to remember, everyone on this site is a computer enthusiast of some sort, and we will always recommend you build your own because that is what we want to do. I understand that some people are not confident enough with tech to do that so don't be put off buying an off the shelf unit. Shops like www.scan.co.uk do good off the shelf systems, that will serve you well if you are not playing PC games.
    However, if you do intend to game, then I also suggest building your own, especially if you are on a tight budget.
    This months issue of Custom PC has a "build your own PC for £400" feature which I recommend you read if you fancy doing it.
    For you, in terms of graphics cards, a 460GTX is probably overkill, an ATI 5770 will do you fine (especially as since you don't know whether or not you will be playing lots of games so there is no point in investing lots of money in them).
    If you want further advice keep asking questions here, we will do our best to help you out.
  15. shah
    shah Minimodder
    29 Jan 2010
    Hey mate,
    I am running a HD5770 and have a 22" monitor. It runs fine but the only game I run is the COD MW2 and have no problems. I think HD5770 should be enough for your needs for now.
  16. samozamo
    19 Jul 2010
    Hi all,
    Thanks for all your replys, I went out and got that issue of Custom PC, which reading through has been interesting and confusing lol.
    PureSilver - I have added that infomation to my original post, thanks for the tip :).
    Thanks for all your help so far. I didn't know what to expect when I first posted on this site, but its been great.
  17. roosauce
    12 Feb 2010
    Subscribe! It's an awesome little monthly treat in your letterbox :)
  18. samozamo
    19 Jul 2010
    I think I will do! I went out and got it Wednesday I think (The August issue) and then went in WHSmiths yesterday and they already had Septembers issue. Is that right? lol
  19. samozamo
    19 Jul 2010
    I was just on jsty3105's thread and they got round to this build, as I'm not looking to get a monitor yet, it would then make the total of this just a fraction over £400. Which would be ideal. Any other suggestions?
  20. roosauce
    12 Feb 2010
    That's right, 'September' just came out. For some reason all of the mags use future dates ...
