Modding Help me out - Frosted Acrylic?
Discussion in 'Modding' started by k3rnel, 28 Dec 2004.
  1. k3rnel
    k3rnel What's a Dremel?
    25 Nov 2004
    Where can I get frosted acrylic online? I have looked everywhere locally and am at my wits end. I need a decent sized sheet.
    Thanks for any tips!
  2. belier
    belier What's a Dremel?
    13 Aug 2002
    If you can't find it anywhere, there is a spray-on frosting that you can get at Home Depot or Lowes that is essentially frosted spray paint. I've done a bit of it on some glass before and it came out well enough, might be worth a shot.
  3. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    This has been asked tons of times before..:search:...but your best bet is to do it yourself in one of many ways:
    1) Most DIY hardware stores sell a self-adhesive sheet that sticks on plexi and gives it a frosted look
    2) You can find spray-paint like sprays that paint a frost on glass
    3) Media-blast the plexi (you can buy sand-blasting spray cans as well for an easy solution)
    4) Sand the plexi down yourself, using lots of different grits of sandpaper, and lots of elbow grease
    :thumb:
  4. k3rnel
    25 Nov 2004
    Thanks guys.
    I do realize its been posted as I did do a search, (heck, even I have posted this question before), but no one ever really answered my question yet. :(
    I know of the ways above from searching, but I really want to buy the real thing. And sadly, I still cannot find a place that sells it.
  5. k3rnel
    25 Nov 2004
    What section was this in? I want to try this one.
  6. Lukethegreat
    Lukethegreat What's a Dremel?
    2 Jul 2004
    hey man, i tryed this with mine, i wanted it to look agged and a bit older, so i tried steel wool. it turned out well. Try it first on some spare plexi glass to see if it is what you want. Hope that helps.
  7. belier
    13 Aug 2002
    The paint department is where I found mine. There should be a section with speciality paints (ie: craquleur, rusted metal etc). If you don't have any luck I'd just ask the aging paint mixer guy where they are.
  8. k3rnel
    25 Nov 2004
  9. belier
    13 Aug 2002
    Interesting. Post pics when you're done, i'd like to see how that comes out.
