I have 2GB of Corsair T W I N 2 X 2 0 4 8 - 6 4 0 0 C 4 D H X 800mhz ram, but CPU-Z says thats its CAS5 at 5-5-5-18 Now i was told to manually enter the correct timings but im a complete newb. Here is my BIOS options (Asus P5Q Pro) Ai Overclock tweaker CPU Ration setting FSB strap to north bridge DRAM Frequency DRAM Timing Control 1st info: 5-5-5-18-3-42-6-3 2nd info: 8-3-5-4-6-4-6 3rd info: 15-4-1-6-6 DRAM Static Read control DRAM read training Mem OC Charger AI Clock twister AI transaction booster DRAM Voltage Here is spec sheet http://www.corsair.com/_datasheets/TWIN2X2048-6400C4DHX.pdf What do i put for each option please?
Just change the first four numbers to 4-4-4-12, that should be about it. P.S. if your not certain on what to do, leave it as it is, its not exactly slow. P.P.S Playing with the BIOS can damage your system etc, so don't blame me or Bit-tech if anything goes wrong
It is currently running at the correct settings. If you want to lower the timings, find the 5-5-5-18 in your bios settings and lower it to the 4-4-4-12. Set your voltage to 2.1v in the dram voltage setting and it should work. Should being the key word here.
I have the exactly same motherboard and exactly same RAM (but 8GB of it) as you and I did that right away and I must say it works like a charm. And the modules are only warm to touch.
