Hello all! sorry for my bad english, but is to dificult for me. First, i said hello all I have a little question for my mod. I have a lian li v1000 and i go to put 2 radiator in HD size: The problem is the height, becouse it is 112mm and the normal of the radiator is 124mm. I cut radiator and modiffy: I will going cut the windows same than that: And use that for the hole of windows: I have 2 posibility for put the fans but i am not sure where is the best: 1º) 2º) The fist have the problem than fans give the hot to mobo but is better for the fans. The seconds is the opposite of first. I go to put he pump in midle of radiators. What u take? other option? The watercooling is this: 1º:Litter river storm g4, 2 double cooltek, mcp600 rev2. 2º: black ice extreme, maze4 vga, made in home for chipset, mcp350. Thx! for your time
Hello all Ithink , than u don't understand me I have a little modification in my box: Now i make a aluminum plate for this hole and i can put 2 soble radiatorem, 4 fans of 12cm and one mcp600 rev2 pump. See you
Hello! i think than i only speek for me I build the part for the case: It need a little moddifier for put in the case. See you
Looks good but why are you using two rads? Are you going to put two loops in there or one? Also why not use circle mesh instead of that hexagon shaped mesh? With the circle mesh it will look better with the front of the V1000. Forgot to mention that #2 is better to have the fans but i would seal off that part of the case from the rest of the case. This way it wont interfere with the rest of the airflow.
He's using two rads because two rads ROCK! Good job! I have the same case and I am installing two double size heater cores too! I am installing mine outside the case though. Anyways,... good luck!
Ummm, 2 rads are just a lot of unnecessary restriction on your flow unless you have the loops to justify it...what on earth are you cooling in there!?
Hello all!!! and thx for your time I have two radiatorem becouse i like the silent system, and i hate the fans... I prefer 2 double radiatorem with one fan than 1 double radiatorem with 2 fans... silence is the best, and i use computer when i am study, and the song is not good idea for understand The watercooling system is that: MCP -> two radiator in parallel(Not in line) -> Storm G4 -> Maze4 -> Reservoirs(Big Tank O Matik). I want to put other mcp between radiators and Storm G4, but i dont have more money. More photos This is the panel for the two hole(is too big but is the smaller in the shop... 15 euros :S): And my water block, one storm g4 of cathar Cheeeersssss
Yup two rads will kill flow big time. You will need a pretty beefy pump to handle that. When the pump gets beefy like that it will be more noisier and your pc wont be silent anymore.
I prefer loose flow rate and win silence. I loose posible 1/2º for less flow rate but i win 1/2º with one more radiator(better fot the tº of water). Is posible the same. More photos Bye!!!!
Agreed. Let's move this to Project Logs. Looks like a good mod, g0su. I like the way you are re-arranging the inside of the case to suit your requirements -- I did that and it is just the best way to go. Do not get discouraged by other people's opinion about your loop. Although I agree that two rads are not strictly necessary, your pump will cope fine and high flowrates are not essential. Well done!
Looks nice Looks damn good, where did you get the molding for the window? the only place I can find any is on xoxide and its like 2.75 a foot. or did you pay that much?
2 D4 :S uffff why u dont buy mcp600 rev2? more more more silence than D4 and better pump than D4... http://forums.procooling.com/vbb/showthread.php?s=&threadid=7931&perpage=25&pagenumber=2 Mmm 2'75 euros? TOO expensive... In spain(yes yes, spain is 3º world XD) this is cheper(i think in eglish is cheper mm not expensive XDDD), 1 meter 1'30 euros in a tunning car shop I prefer this waterblock jeje but i don't have more money(some friends have this waterblock or they are waiting for sent an order of Australia(country of cathar): The computer is not down, the problem are when i play enemy territory, becouse i close the apache for stop lag Later i up some more photos Cheeers and thx for your help
