Help my computer is broken.!!!!!!!!!!!
Discussion in 'Hardware' started by MikeTitan, 24 Jan 2004.
  1. MikeTitan
    MikeTitan Ling Ling: 273 Battle Points
    4 Mar 2003
    Ok was playing a game of TO when my computer turned off, i didn't think nothing of it until I tried to turn it on again and it wouldn't turn on. Sometimes when i hit the power button the board lights up and stuff for like a split second but then quickly turns off. I did not have this computer overclocked, Plus my video card has a new fan that makes it run like a dream and my CPU has a big Zalman Sunflower cooler CN-7000 i believe? It has never done this before. It makes it look like my power switch is the dodgy item but i don't know for sure. Im checking all the connectors right now to make sure but it looks like everything is connected.....
    please help :waah: :waah:
  2. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    From my 7 months fixing broken computers off production lines, I'd say that that's about 75% likely to be the PSU, 15% motherboard, and 10% something else. If at all possible, try another PSU, then work from there - unplug everything apart from CPU, RAM and GFX, then if it still doesn't work, try to eliminate them (got two sticks of RAM? Put each of them in in turn) until you determine what's causing the problem. Good luck!
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Good chance its PSU, wont be the power switch I think as thats momentary.
    Does it switch on OK if you leave it for a while, might be an overheat protection facility on the motherboard.
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Sounds very much like a PSU issue, tho u say u get momentary switch on, which could be some sort of over current protection.....
    Check with a new supply then as suggested remove all non essential parts and test.
  5. Bloodsmoke
    Bloodsmoke What's a Dremel?
    20 Jan 2004
    I would also say PSU, to check you can take it out and jump the 4th pin to the 6th and see if it starts.
    :thumb:
  6. Malvolio
    Malvolio .
    14 Dec 2003
    I had the same exact problem with my main rig last friday, turned out it was the psu (no clue why it died... proably drew more than it was willing to give). So, as suggested multiple times, try another psu!!
  7. mulberrycrush
    mulberrycrush Minimodder
    26 Sep 2001
    I would agree on PSU, mine did the exact same, and it was a bad PSU.
    :thumb:
  8. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Don't know about you guys but I'm starting to think it might be a power supply problem :D :D :D
  9. Kameleon
    29 Apr 2003
    Actually I was thinking PSU, but you might be right :hehe:
  10. Tim S
    Tim S OG
    8 Nov 2001
    ok guys, enough of the replying for the sake of replying... If you've got nothing to suggest that it isn't a power supply issue in this case, please post... anymore posts that say "I think it's a PSU problem" from anyone other than the thread starter, I'll be removing those posts as soon as I see them.
    Thanks
