Electronics Help needed from an Electronics expert :)
Discussion in 'Modding' started by pumpman, 14 Feb 2007.
  1. pumpman
    pumpman Minimodder
    7 Jul 2004
    I have a bit in an electronic calculator/head of a petrol pump thats gone pop and because its an uncommon pump im not up on its foibles. Its been sitting for a long time and there was a lot of dampness in the enclosure but its been dried for a few weeks in my workshop.
    Ive put 240v into it to test it and it powered up fine but then a component popped and im not sure what it is or does as the model is alien to me
    It has on it PMR 2026 its made by Rifa IT also has RC Unit on it and on the back is the rating 630v dc /250v ac
    what does it do and any idea why it would pop its been wired into a solid state relay that operates a 240v single phase motor if it helps
    thanks
    __________________
  2. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    do you have any pictures of the thing that popped? if it was a capacitor that got water in it, it could have not been dried out... or something similar.
  3. pumpman
    pumpman Minimodder
    7 Jul 2004
    one of the connectors has fallen off due to the zapping
  4. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    This is the closest thing I could find to it. Will need to do more searching for a supplier with a smaller minimum order.
  5. pumpman
    pumpman Minimodder
    7 Jul 2004
    yep thanks for that :) I can get a hold of one , id like to know what it does if possible
    thanks
  6. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    It's basically a noise/transient/surge type power filter.
  7. pumpman
    pumpman Minimodder
    7 Jul 2004
    thanks for that :)
