bought meself a nice new 'spiffing' sony psone screen today them official ones, damm sodding cheep soldering iron ive removed the tracks off the bottom pcb, (where u solder on the wires to convert to VGA,), now i need your all your guru help the header from the mainboard marked cn4 has 12outputs 2 for the power supply pcb, and the other 10 for the other pcb, would anyone be so kind as to be able to draw what each one is or how i wire it up or whateva, i dunno just anything im like totally f00kered soldering never was my good point please help thanks in advance Dean
If you lifted the tracks off the PCB, your soldering iron was too hot for the job. Used a 40W one? 25W is the highest you can go, really. I have a 12V Antex iron (about £15,--) for really finnicky work. Takes a bit longer to warm up the solder, but you're not likely to do any damage (for those with real money to spend, an adjustable iron is the best solution). Anyway, look at the PSOne modding thread in, er, Modding.
