Help with NF7-S 2.0 Beep codes
Discussion in 'Hardware' started by Hiren, 2 Jul 2004.
  1. Hiren
    Hiren mind control Moderator
    15 May 2002
    Right the other day I was benchmarking when my NF7-S shutdown my PC and started beeping. I thought it might be due to my 2800xp over heating (had very high temps recently).
    So I shut down tried a different fan combination. Switched on and now the PC refuses to post, the fans spin up board starts to beep and everything shuts down. Having looked in the manual I can't find any reference to what the beeps mean.
    So fellow Abit owners has anyone else experinced this? If so what does it mean and how can I sort it? :wallbash:
  2. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Might help if you told us the beep pattern...long continuous beeping, one long two short, high-low siren, what?
  3. Hiren
    15 May 2002
    :wallbash: high-low siren. Sorry thought I'd included that.
  4. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    It probably means that you lived up to you're title :baby:
    Can you possibly tell us the combination of beeps?
    Cheers,
    Mike
  5. Kameleon
    29 Apr 2003
    Unfortunately that looks likely :blah: Reset CMOS, reseat the CPU and have a look at it. Have you got another Socket A CPU you can try?
  6. Hiren
    15 May 2002
    Nope fraid not at the momenet, might be able to get hold of one over the weekend.
    Reseated CPU and reset CMOS nothing happening though.
    Edit/ It's just a constant high low siren that beeps from the mobo nothing else.
  7. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Well, The Barton M is a really nice item to get at this time... Sorry dude, your CPU is dead. :(
  8. SFOD-D LoneWolf
    10 Apr 2004
    Forced upgrades, the best kind :naughty:
    Cheers,
    Mike
  9. Kameleon
    29 Apr 2003
    Not necessarily, it's equally likely that the mobo is gone...
  10. RotoSequence
    6 Jan 2004
    You know, I should have realised that too. Since Avalon did die, and the motherboard is what went when it initially looked like the CPU had failed. :duh:
  11. Mister_Tad
    27 Dec 2002
    oh man, i didnt know it was possible to have such bad luck with hardware, you have to be moving onto a new record :wallbash:
    last time i heard the low-high siren sounding beeps it was a dead motherboard, but that wansnt on an abit at all so i suppose that isnt much help
    i have a spare duron cpu you can pinch if you want to check if it is the cpu or not
  12. tian905
    tian905 What's a Dremel?
    24 Apr 2004
    Try posting it without memory or a graphics card inserted. If the beep codes change then the board may not be dead.
    I've had some bitches of NF7-s with regards to posting, also try posting without the BIOS chip in place then replace the chip and try again, it worked for me once. Also remove battery and leave it to sit for a while, but I wouldn't hold my breathe if you get to that point.
    If you think the board is dead it's gotta be worth giving the above a try, also ensure that you replace the BIOS chip the right way round as you'll cook it otherwise, I know that from experience.
    Hope it helps
    C ya
    Ian
  13. Hiren
    15 May 2002
    Well it seems to be working :eeek: Not quite sure how just did some fiddling with the cpu and it gets into windows. Still reporting high temps though.
  14. Firehed
    15 Feb 2004
    Not necessarily, I've seen a CPU in a dead NF7-S and it just did some assorted beeping (like some long 5-second ear-shattering thing!). But something is definately dead. I'd think PSU myself.
  15. Howitzerflagz
    Howitzerflagz What's a Dremel?
    24 Apr 2004
    dam...n u r soo bad ! come on !!
