Disaster Help with pumps
Discussion in 'Modding' started by the scunner thommo, 22 Oct 2012.
  1. the scunner thommo
    the scunner thommo What's a Dremel?
    27 Oct 2011
    Just had a major floodage and seems that my Aquaero Pro 5 has blown- it will only power up one of my 2 pumps.
    Pumps work if plugged into molex cables but I can't control them- any way I can do so if the AP5 has blown?
    The pumps have a mloex connector and a single pin fan controller
    HELLLP!
  2. Nexxo
    23 Oct 2001
    The only way to control them manually is via a sufficiently powerful PWM fan controller that can handle the draw on the pumps. Else you are looking at an Aquaero or similar electronic setup that has temp sensors and fan/pump controls.
  3. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    sorry but cant help ya there... mayby try rma'ing it? it wasnt caused by the owner after all. other than that ill leave it to the experts..
  4. the scunner thommo
    27 Oct 2011
    thanks- I will try using my spare Lamptron Touch to see if it works as it claims to have 30w per channel
    Will I need any special connector for this as the 3 pin out of the pump only has a blue pin (single)
  5. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    ^^ this
    use one of Lamptron's high-power fan controller - it manages up to 30w per channel. but it lacks "algorithmic" controls. also there is sunbeamtech rheosmart with ability to control fan/pumps via PWM signal from MB
