Development Help with SQL Queries and Variables
Discussion in 'Software' started by mnorth, 7 Mar 2008.
  1. mnorth
    mnorth What's a Dremel?
    10 Jan 2006
    I’m trying to build some sql queries in query analyzer (eventually for use in stored procedures).. I’m not very good at explaining so I’ll try and use examples.
    Question 1
    I need to build a query dynamically based on some variables
    So here is an example table
    Code:
    [Field1]      [field2]       [field3]
    A		1		DATA
    B		1		DATA
    C		1		DATA
    A		2		DATA
    B		2		DATA
    C		2		DATA
    A		3		DATA
    B		3		DATA
    C		3		DATA
    This works
    Code:
    DECLARE @myVar AS VARCHAR(50)
    SET @myVar='A'
    IF (SELECT @myVar)='A'
    	SELECT *
    	FROM test
    	WHERE field1='A'
    IF (SELECT @myVar)='B'
    	SELECT *
    	FROM test
    	WHERE field2='1'
    But I’m trying to do is achieve the same results using the below format.
    Due to the final query having multiple conditions and variables.
    Code:
    SET @myVar='A'
    SELECT *
    FROM test
    	WHERE field1='A'
    ELSEIF (SELECT @myVar)='B'
    	WHERE field2='1'
    ENDIF
    Question 2
    I want to select a field from a table (again) dynamically based on variables.
    So using the above table again I’m going for
    Code:
    SET @myVar='field1'
    SELECT @myVar
    FROM test
    I don’t know if either of these are possible but any help would be much appreciated.
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    google sql CASE
    Code:
    SELECT   ProductNumber, Name, 'Price Range' =
          CASE
             WHEN ListPrice =  0 THEN 'Mfg item - not for resale'
             WHEN ListPrice < 50 THEN 'Under $50'
             WHEN ListPrice >= 50 and ListPrice < 250 THEN 'Under $250'
             WHEN ListPrice >= 250 and ListPrice < 1000 THEN 'Under $1000'
             ELSE 'Over $1000'
          END
    FROM Production.Product
    ORDER BY ProductNumber
    hope it helps
    hmm looking again at your problem it might not what are you using to call you rSP
