help with upgrading old dell p3 450mhz to 600mhz
Discussion in 'Hardware' started by n0d4x, 16 Aug 2007.
  1. n0d4x
    n0d4x What's a Dremel?
    1 Feb 2007
    I have a old dell p3 im making my linux project to kill time it has a 450mhz processor I got a 600mhz processor from my buddy and I put 640mb of ram in it
    the processor fit fine booted right up said "p3 600m" on startup then after about 10 seconds of running it shut down with the fan still running it overheated so I pulled it out it was hot as hell
    how do I upgrade to the 600mhz processor or can I not? it has alot smaller heatsink then the 450mhz thats in it now
    thanks
  2. Skylined
    Skylined Minimodder
    3 May 2003
    Get a propper heatsink, fan and check the CPU voltage.
  3. n0d4x
    1 Feb 2007
    hmm well I could take the one off the 450mhz one and put it on the 600mhz
  4. n0d4x
    1 Feb 2007
    crap the 600mhz is fried now because I didnt install it wiht the right heat sink the first time
    crap crap crap crap
  5. Amon
    Amon inch-perfect
    1 Jun 2007
    Is this on Slot 1 or the or the socket version?
  6. n0d4x
    1 Feb 2007
    umm not sure its right in frotn of the fan and it slides in and clicks
