I have just got my 920 Pro DVi and am really pleased with it. I have only one small problem..... when the sytem "switches off the monitor " ie after 5,10,20 etc mins the screen goes into standby mode as it should, but when I wiggle the mouse, press a key the monitor wont return to normal. I have to press rest on the compo and reboot. Also if I turn the monitor off by pressing the power botton ( as when going off and downloading ) when i press power on it wont return to windows??? I hope im explaining this ok???? The monitor is attached to a sapphire 9800 pro. DVi con with the dvi/dvi con in line which came with the monitor. DVi is set in menu. Any ideas please??
