Other Hi, 1:1 backup?
Discussion in 'Gaming' started by Simnol, 8 Oct 2009.
  1. Simnol
    Simnol What's a Dremel?
    3 Jun 2009
    Recently I've started getting all of my games online, through such sources as Steam, I find this great because anyone will tell you that I'm impossibly bad at keeping track of CD's and finding them when I want to play a game can be a pain.
    To this end I've decided I want to back up all of my PC games to my external hard drive (and before you say it it's not illegal, I checked and I'm exercising a legal right).
    So does anyone have any idea how I could create a 1:1 .iso (or other format that's virtually mountable) so that I can keep them along side my game files and mount them when necessary?
    I've had a look at some Slyfox software, Alcohol 120%, CopyCD, Nero but none of them do true 1:1 including copy protection (again what I want to do is perfectly legal under EU legislation).
    Could I get a new DVD drive that would make a true 1:1 image?
    Any help / pokes in the right direction would be lovely.
    P.S. I only have about 20 games still but they range from the 90's (E.G. Little Big Adventure) to some later ones (E.G. Oblivion and a few Games for Windows Live games which I'm told are notoriously troublesome).
  2. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Why would you want to? The whole benefit of digital distribution services like Steam is that you can just re-download the game whenever you want to. Their servers are the backup, so you don't have to do it.
  3. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Ive got slysofts anydvd and it works perfectly, Ive been converting all my dvds to .iso for my media center. The only disk ive had that it hasnt worked with is silent hill, no idea why though.
  4. Simnol
    3 Jun 2009
    Read my post properly before replying.
    Edit: That was harsh, I was implying that I need to backup my older games, I'm well aware of Steam and it's system.
  5. Simnol
    3 Jun 2009
    And it makes true 1:1?
  6. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Yeah, sorry I misread your post :duh:
  7. 13eightyfour
    9 Sep 2003
    I assume so , I put the disk in select copy to .iso, select where to save it and it does its thing.
    The files are massive though 4Gb+ and if i burn it back to a dvd i get the exact same disk as the original, with no quality issues,
    You can download a trial off there website, its only a small download and should only take minutes.
  8. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    And you don't need to worry about anyone on this forum moaning because your backing up.
    I'm sure most of the people on here agree that the laws that state that you aren't allowed to back things up etc are complete BS.
    oh, and welcome to Bit-Tech
  9. robddav
    robddav What's a Dremel?
    26 Sep 2009
    daemon tools?
  10. unknowngamer
    unknowngamer here
    3 Apr 2009
    Open steam.
    File menu.
    backup games.
    Saves downloading them, if you need to reinstall, or install on another PC. open the folder and run steambakcup. job done.
    You might want to back up any save games from my docks.
  11. 13eightyfour
    9 Sep 2003
    Hes already said twice that its NOT the steam games he wants to backup :eyebrow:
  12. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    it's a pretty badly worded post, then! i didn't get that at all.
    anyway, cloneDVD should do it for ya. you might still need a securom crack though.
  13. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Doesn't read that way. "I started getting all my games online including steam I now want to back them all up". :worried:
  14. Simnol
    3 Jun 2009
    I know this thread is now two years old, but that's not what I wrote in the first place...
  15. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    necromancer!!!
  16. Jedra
    Jedra Supermodel
    11 Sep 2010
    I suggest you borrow a tape-to-tape machine. You can make a toastie in your brevel toaster and watch the generation game while you wait...
  17. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    In a thread asking how to backup 1:1.
    The rest of your OP not mentioning you already know about Steam backups.
    :thumb:
  18. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    To directly answer your question: I'd recommend PowerISO, which is what I use for opening/editing/creating/burning/mounting images. It's gimped in functionality without registration but otherwise it's power and worth it as a be-all end-all image program.
    Now having said that, tbh it's totally pointless to use anything other than Steam's built-in backup feature. Regardless of the situation I can't understand why you wouldn't just use it. But that's just me.
  19. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Great thread necro, and great posts ignoring the OP.
