Electronics homework help...urgent
Discussion in 'Modding' started by ido, 20 Mar 2003.
  1. ido
    ido What's a Dremel?
    12 Sep 2001
    Can you fry an LED if the voltage and amps are over its tolerances even if it is hooked up wrong = current not going through it?
  2. guzzler
    guzzler What's a Dremel?
    14 Dec 2002
    in what way is it connected wrong? If its connected the wrong way round (ie, cathode is more positve than anode) it is possible to fry it...
    g
  3. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Yeah but they have to be pretty high, cascade voltage i belive they call it, when the diode has too much current trying to get through it the wrong way.
  4. RTT
    RTT #parp
    12 Mar 2001
    'reverse bias' and yeah, over a certain amount it'll die :)
  5. ido
    12 Sep 2001
    thanks for the quick replies. Yea, i ended up putting that it would fry the LED. Sorry that I couldn't be more specific, the exercise was in french so I didn't know how to translate a lot of the scientific terminology.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Not that high, 5v max reverse voltage is the usual spec. They'll often stand a few volts more, but connect one wrong way round to a 9v battery and you've a dead led. :waah:
  7. Amorphus
    Amorphus What's a Dremel?
    25 Feb 2003
    doesn't it depend largely on amperage, too?
    oh no, you're out 20 cents! :rolleyes: :lol:
  8. Guest-2867
    Guest-2867 Guest
    Hehe, reminds me of the time when I was trying to explain this to a friend, I connected it the wrong way over a 9V battery, yet it still worked, making me look like a right fool, then i said 'right you little F£$^%"£' and connected it through 30V 350mA reverse bias, AND IT STILL WORKED! :eeek: Dem thing just wouldn't die :lol:
