Storage Hot Swap question
Discussion in 'Hardware' started by Bladesingerz, 23 Sep 2012.
  1. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Hey everyone I'm planning a new desk build and I'm looking into Hot swap bays, I would like to get something of a 3x5.25" bay to 5x3.5" drives.
    Something like this http://www.pc-pitstop.com/sata_cages_enclosures/mb455spf.asp but a cheaper version or something.
    I was only wondering about the noise of the fan and drives, don't they vibrate alot inside a hot swap bay?
    ~Bladesingerz
  2. zulu9812
    zulu9812 What's a Dremel?
    21 Oct 2010
  3. Bladesingerz
    30 Nov 2011
    Oh that looks like a nice unit, very handy to have the eSata and usb there to! To bad the leds on it are blue, realy like it to be red.
    So ok is it safe to assume most hot swap bays are quiet? (asuming they are not junk)
    What about heat? Do you really need the fan on it? I'll have 2 fans near it blowing cool air in.
  4. zulu9812
    21 Oct 2010
    As far as fan noise goes, you can always swap out the fans. I have three of these units in my fileserver - http://www.specialtech.co.uk/spshop...Drive-Rack-Mount-Kit--EX-H34SX-pid-12049.html
    Each one comes with a Lian-Li 120mm fan which are pretty quiet to begin with, but I swapped them for Apache Blacks and linked them to one PWM slot on my motherboard. And honestly, sometimes I'm not even sure that the computer is turned on but for the power LED (that's how quiet it is).
    As far as heat goes, I've never really worried about it. In the IcyDock unit, I've had the fan switched to low for the last year and never worried about the heat. And it's only a 80mm fan to begin with, so I could probably remove it altogether. I only run the 120mm fans on the Lian Li units because they actually double as the air intake for the case.
  5. doyll
    doyll Minimodder
    1 Jul 2011
    I know I'm a cheap barstuard but have one of these in my system now for 8 months no problems.
    Ebay 3.5 SATA HDD-Rom Serial ATA Hard Drive Disk Mobile Rack £7.88. Item number: 140540356747
  6. Bladesingerz
    30 Nov 2011
    not a bad price really! But I like to get something fancy for my next build.
    Got an other question, if you place your HDDs vertical will they break down faster? Since all the pressure of the disk is on 1 side of the bearing (or what ever holds it in the middle)..
  7. zulu9812
    21 Oct 2010
    That, I couldn't tell you.
