Cooling How a Core/rad/coil works
Discussion in 'Hardware' started by thorilan, 22 Jun 2004.
  1. thorilan
    thorilan What's a Dremel?
    25 Aug 2003
    For those of you that want to learn the workings and considerations of heat exchange in a core/rad and how some basic principles may improve your performance. The info for this comes from many different sources and hopefully this will be less confusing than some of the other explanations that are out there
    The purpose of a finned tube heat exchanger (the technical name also known as a rad core or coil) is to isolate two different mediums so that they do not touch or mix together, and to transfer the heat from one medium to another.
    To achieve heat transfer, there must be a difference in temperature between the two mediums (gas and/or liquid which refurs to the air outside of your rad and the water inside your loop), a pathway made of materials that allows conduction of heat so it can convey from one location to another( the surface material of the core which is usualy copper or aluminum with some brass), and a means of exposing the heat to the fluid medium (the water block ). If any of these items are missing, heat transfer will not occur.
    This is reflected in the basic relationship from which all heat transfer equations are derived:
    Q = U A DeltaT
    where
    Q = Amount of Heat Transferred Over Time (BTUs/hr)
    U = Heat Transfer Coefficient (BTUs / ft2-￾‹F-hr)
    A = Area Available for Heat Transfer (ft2)
    DeltaT = Temperature Difference (￾‹F)
    Changing any one of these values affects Q (the amount of heat that is transferred).
    U =Overall Heat Transfer Coefficient is affected by the thermal conductivity of the materials that the tubes and fins are made of, the viscosity and thermal conductivity of the two mediums and the velocities at which these mediums move through the rad/core . NOTE in larger systems Medium velocity (Medium as in the liquid and gas , aka air and water) is important because a thin layer adheres to the rough surface of the metal thereby slowing the movement of the medium. This creates a laminar layer that insulates the bulk of the medium from touching the tube and/or fin surfaces. As a general rule, the faster the medium moves, the more turbulence is created, which breaks down this insulating laminar layer.
    A =Heat Transfer Area of the fin and tube material exposed to the mediums. Air and gases are poor thermal conductors so more surface area is needed for heat transfer. Both sides of a single fin are exposed to the air or gas so when fins are stacked close together they create a very large amount of heat transfer surface area. Liquids usually flow inside the tubes and are good thermal conductors requiring less surface area. Tubes are the Primary Heat Transfer Surface and fins are the Secondary Heat Transfer Surface. It is important to have good metal contact between the fins and the tubes because without it there is not a thermal pathway for heat to move.
    DeltaT =The temperature difference between the two mediums. "U" has to do with conveying (conduction and convection) the heat and "A" relates to exposure to the heat. But the DeltaT between the mediums as they move through the rad/core is the driving force that makes the heat want to move from one medium to the other. The greater the difference , the more heat that will be transfered .
    Some of the coil's physical attributes that affect the heat transfer coefficient, like the tube pattern, tube size and distance between the tubes, also affect the amount of heat transfer area. Increasing the fin height, fin length and the number of tube rows deep increases the heat transfer surface of both the fin and the tube. Adding more fins per inch increases the surface area of the fin exposed to the air and changing the tube pattern in the fin can add more tubes. Again, more is better to a point. Too much surface area could lower velocities through the coil and add cost. Too little surface area could raise velocities, thus friction losses, and shorten the coil's service life. Depending in which dimensional plane (i.e. fin height, fin length, rows deep) the coil surface area is changed, there is increased or decreased cost involved . Even with the best heat transfer coefficient and largest heat transfer surface area configuration it is STILL the temperature difference that drives the heat transfer. Its importance can be seen by looking back at the basic heat transfer equation Q=UA DeltaT . In larger systems IF only the DeltaT in the equation is changed from 1￾‹ to 2￾‹ the heat transfer is increased by 100%. Changing the DeltaT to 10￾‹ increases heat transfer by 1000%.
    Obviously it is very important to maintain a wide temperature difference between the air and water (gas and liquid). Making sure this occurs in a rad requires that the liquid in the tubes moves through the coil in the opposite direction (counter flow) to how the gas, on the fin side, moves through the rad. This even applies to chambered cores but to a much smaller extent as cores are a much smaller system and the difference is very small .
    The circuit path of the medium should also be designed for the liquid to enter the coil at the lowest point and exit at the highest point. This allows any air in coil tubes and/or in the incoming liquid to float upward with the liquid flow and out of the coil providing automatic air venting or " Bleeding". If a core/rad is not bled, air may become trapped in several tubes, insulating the liquid from touching the tube wall, which lowers core performance .
  2. thorilan
    25 Aug 2003
    wow not a single reply.
    :grr:
  3. Hephaistus
    Hephaistus What's a Dremel?
    11 Mar 2004
    Could you explain this again please, English is not my native language and i don't understand what you're saying here.
    Do I understand well that you mean that the faster the water goes trough the rad the better it cools.?
    Btw some nice information you have here :clap:
  4. Firehed
    15 Feb 2004
    From a quick look I think that's saying the more turbulance the block has, the more heat it takes in.
    Water going through a radiator too quickly wouldn't really allow it enough time to cool off....
  5. Hephaistus
    11 Mar 2004
    So best is when the water is going very slow trough the rad :confused:
  6. thorilan
    25 Aug 2003
    this is correct
    this is not
    if you paid attention at all to what i wrote you would notice that the most important factor to the delta is the DIFFERENCE IN temperature which means as the meduims get closer to equilibrium ( the same tem by 1 cooling down and 1 heating up ) they give dimminished returns . so you want the water to flow as fast as possible to keep the diference between the 2 as wide as possible
    imagine a hot skillet
    to cool it you could pour warm water on it which has similar heat . or you could pour ice water on it.
    which would you choose?
    i choose the ice water.
    why?
    because its colder ( has a higher diference in temp which is just common sense)
    but you notice that when the water warms up in the pan or skillet it doesnt cool as well any more.
    so oyu have to replace it with more ice water. SO the longer it sits in the pan ( our rad) the closer the temps get but the less efficient
    if it where true that water needed to travel slowly then we would make our water travel at a crawl .
  7. thorilan
    25 Aug 2003
    the surface of all things in the world are not completely flat
    so they creat some amount of friction . it also means there are high and low spots.
    well what happens is water has something called tension . the tension makes it so that water clings to the side of things. the more smooth the surface the less it clings or sticks
    the thing is it builds a layer in which the water does not come off the surface so that a thin covering of water that DOES NOT MOVE stays between the water that is moving and the metal surface that is suposed to transfer the heat. so that thin layer of water that doesnt move is lowering the ability for heat to transfer because its not moving and holding the heat it has stored ( forming something like a heat blancket)
    thsi is the best i can do to explaine this in a simple english way atm. i could think a bit more but im at work atm
  8. r3Q
    r3Q Minimodder
    31 Jul 2002
    basically;
    there is a layer of water that is stagnant inside a tube (the radiator or heatsink) that touches the metal.
    to get this layer gone and get more water to touch to metal and absorb heat; there must be turbluance to tear it off.
    hence; high flowrates = high turbulance = no stagnant water = cooler temperatures. :thumb:
    hope that gets rid of all the jargin that us normal people dont understand.
  9. Hephaistus
    11 Mar 2004
    ok thx now i get it
