Graphics How big is a 6800 GT?
Discussion in 'Hardware' started by Morphious, 24 Aug 2004.
  1. Morphious
    Morphious What's a Dremel?
    19 Jan 2004
    I read somewhere that it takes up the AGP slot (obviously) plus a PCI slot - so how big is this thing? Will it really take up that much room?
  2. tmod
    tmod What's a Dremel?
    9 Apr 2004
    Only the 6800 Ultra has a dual-slot cooler, although there might be GTs with special cooling solutions that take up two slots (the Gainward GT maybe).
  3. Morphious
    19 Jan 2004
    I'm planning on purchasing the eVGA one. :)
  4. tmod
    9 Apr 2004
    The eVGA GT is single slot, but it still isn't a good idea to have anything in PCI slot next to it anyways.
  5. Morphious
    19 Jan 2004
    I won't unless I absolutely have to then. Maybe I'll get one of those lame slot coolers. :p
  6. Austin
    Austin Minimodder
    16 Jul 2004
    http://www.nvnews.net/reviews/evga_geforce_6800gt/index.shtml
    :naughty: Those lame PCI slot coolers are pretty lame AFAIK, loud and not that great. The 6800GT are pretty long, following in nVidia's tradition but as said they are normally single slot coolers. Also as said it's always best to avoid using the PCI slot next to the AGP one, not only because it restricts airflow but because resource conflicts are too common. The 6800GT isn't a monster, well no more really than the Rad9800XT or FX5900ultra.
  7. JoKeR
    JoKeR What's a Dremel?
    23 Apr 2004
    the MSI 6800gt is a single slot card but it did turn out to be about an inch longer than my ASUS 9800xt, which some people may find a bit of a problem. I had to re-think my cables a little, but i wouldnt worry to much about there size they should fit in most cases without to much upset :thumb:
  8. tmod
    9 Apr 2004
    Sorry for the OT...
    JoKeR, when/where did you get your MSI 6800GT? Also, does it look like this:
    I'm just curious as to whether they are shipping them with the nVidia reference coolers, or the custom ones shown above (I have an MSI 6800GT backordered...). Sorry for the OT...:blush:
    BTW, the above image is of a single-slot cooling solution. Gainward does use dual-slot cooling on their GT, but not the regular 6800.
  9. MovieFreak
    MovieFreak What's a Dremel?
    10 May 2004
    Thermaltake makes a heatpipe system (yeah it is huge) for the 6800's, afaik zalman does not have one compatible with it yet.
    And I have this much to say. I love it. Much cheaper than watercooling it also. :)
  10. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    Yea i agree with you, but you knowww you still wanna watercool it :D
    Death
  11. JoKeR
    23 Apr 2004
    I got mine from OCuk and yes it the same as the pic in your post :D
    came with XIII and Prince of Persia
    the over clocking software is quite good as well
  12. JoKeR
    23 Apr 2004
    for got to say when :duh: 22nd of this month
    should also mention that the fan has a switch on the side to increase fan speed.....which is nice!
  13. tmod
    9 Apr 2004
    Thanks for replying. :D It looks good...the cooler is made by ARX, too.
