Networks How can I hook up two computers?
Discussion in 'Hardware' started by Laosa, 6 Dec 2005.
  1. Laosa
    Laosa What's a Dremel?
    1 Dec 2005
    :rock: I just got two computerss and I need to hook them up. What do i need?
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    A crossover cable.
    If you wish to add more computers in the future, a switch and some network cables.
    Remember both cards will need a network card, most modern computers have it onboard anyway.
    Wireless is another option.
  3. Laosa
    1 Dec 2005
    Thanks. Can you get a network cable anywhere?
  4. MrWillyWonka
    25 Jul 2004
    Any electronics or computer store will do them, even a supermarket will do them. However crossover cables are a little more specific and cost more.
    Check newegg for a crossover cable.
    If you want a switch and network cables, check newegg too, note that crossover cables will only work directly between two computers, it will not work connected to a switch.
  5. Laosa
    1 Dec 2005
    Thanks.
  6. mcbeckel
    mcbeckel What's a Dremel?
    31 Aug 2003
    Is at least one of the workstations running XP? If all you really need is a normal network cable instead of a patch cable as XP will automatically perform the crossover (and they are cheaper too). Remember the you have to statically configure the IP addresses on each nic so that they are in the same subnet.
  7. 731|\|37
    731|\|37 ESD Engineer in Training
    5 Sep 2004
  8. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    Google, then we need the ban hammer.
  9. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Its the network card that does the crossover, not the OS.
    Shepps, bit harsh don't you think?!
  10. Shepps
    5 May 2002
    Not really? Seen any of his other posts? :p
  11. Sam0r
    24 Jun 2005
    Good point.
  12. Laosa
    1 Dec 2005
    sorry
  13. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Don't be, you didnt know the answer so you came to a computer hardware site to ask.
    Yes a little google'ing would have produced the answer, but you now know that, but don't be afraid to ask, you will usually get the answer in the end.
  14. Laosa
    1 Dec 2005
    thanks. At least one person is nice to me. No offense to anyone else.:smile:
  15. MrWillyWonka
    25 Jul 2004
    You saying I'm not being nice? :eyebrow:
  16. Hepath
    Hepath Minimodder
    20 Oct 2003
    When I tried hooking up Xp to Win2K I *had* to use a crossover cable, not a normal patch cable - anyone managed to do this using a normal patch cable?
    Also, unlike linking 2 XP based machines, you cant use the XP wizard and create a networking disk as Win2k will not accept it. Pain in the butt - so as McBeckle said you have to configure the IP addresses, subnet masks invididually. If I remember correctly, Xp uses the 192.168.*.* pattern for local IP addresses (using a 255.255.255.0 subnet)
    Laosa - you still havent told us what OS the machines run.
  17. Hepath
    Hepath Minimodder
    20 Oct 2003
    Lasoa
    Please try to keep youre related questions in a single thread....! It makes it much easier for people to follow what is happening.
    I have posted in your newest thread.
  18. MrWillyWonka
    25 Jul 2004
    Lasoa is running XP and 98 via a router now...
    and Hepath, you have to use a crossover cable when connecting two machines directly and one is not using XP, if you use a normal patch cable you can't transfer data because the "send port" would be connecteed to each other, and the "recieve port" would be connected to each other, making the connection useless.
    A crossover cable switches wire round somewhere in the cable so that the send is connected to the other computer's recieve, and vice versa.
    Setting up the IP. subnet mask and default gateway is easy and shouldn't be a problem in any OS, but it's definatly more user friendly in XP.
    Unless one of the computers is running a DHCP server, you will have to configure the IP addresses manually.
  19. Hepath
    Hepath Minimodder
    20 Oct 2003
    Yes I thought so too - which is why I questioned it as this confused me:
    *edit*
    Will be posting in the other thread from now.....
  20. MrWillyWonka
    25 Jul 2004
    I should also mention that I'm talking about Lasoa's situation.
    If you have two XP machines you can use a normal patch cable, but only some network cards support this feature.
