HOW DO I SETUP MY TV TUNER?
Discussion in 'Tech Support' started by Aman, 11 Apr 2007.
  1. Aman
    Aman New Member
    22 Oct 2006
    ok i am using
    http://www.newegg.com/product/product.asp?item=N82E16815116620
    i want to record my xbox 360 while playing on tv which uses composite i think. It's the red blue and white wires..
    someone told my i need a splitter or something
    can someone give me a link to all the wires i will need the comp is about 10 ft away from tv.
  2. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    composite is yellow, component is Red-Green-Blue, audio is the red/white pairing
    newegg is currently down, but if it has a yellow-red-white attachment like mine then all you need is to check that your TV has a Yellow-Red-White output on it and connect that to the TV tuner.
  3. Aman
    Aman New Member
    22 Oct 2006
    i know what i need to so but i don't know what the splitters or wires are called so i need a link i can buy from?
  4. Bluephoenix
    3 Dec 2006
    your original link is dead, can you provide a Manufacturer and model?
  5. Aman
    Aman New Member
    22 Oct 2006
  6. Bluephoenix
    3 Dec 2006
    same model as mine, you don't need an adapter, just plug the Xbox 360 into the TV through the composite connector, and connect the TV's red-white-yellow out jacks to the tuner card's red-white-yellow inputs using a generic composite cable.
    I do the same thing to record gameplay on my system, no complex adapters necessary.
    if your TV doesn't have a composite or S-video out functionality then all you need to do is get a signal splitter (available from radioshack or equivalent for about $10US)
  7. Aman
    Aman New Member
    22 Oct 2006
    yeah i need the signal splitter!!! can you give me a link?!?!
  8. Aman
    Aman New Member
    22 Oct 2006
  9. Aman
    Aman New Member
    22 Oct 2006
    can anyone help me find a composite video 1 into 2 splitter please?
  10. krimson
    krimson New Member
    16 Nov 2006
