Modding how easy is it to take ATX cases to LANs?
Discussion in 'Modding' started by retrogamer, 25 Oct 2004.
  1. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    well heres my dilema... im definately going to build my case - but the thing is, I dont know whether to go with an ATX size mobo (s939) and have nice features and great to OC ;) or a mATX (s754) version which can be smaller and portable...
    so I was wondering, would it be better to have a good ol atx size rig, or go matx :)
    thanks for your expert opinions :thumb:
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    It's a personal thing, but if you have a car then there's no problem taking a full tower to a LAN, done it myself.
  3. retrogamer
    23 Aug 2004
    hehe, well I dont personally have a car (it wouldnt be very safe if I did :worried: ) im only 16 :p
    but lift off one of my parents will be easy to score :thumb: just wondering if it was kinda difficult lumbering around with one :hehe:
  4. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    I just use the box that came with my case when I bought it.
    Maybe someone should make a case for a case!!
    Ohhh the irony! :wallbash:
  5. Anakha
    Anakha Minimodder
    6 Sep 2002
    How about something like this ?
    I don't think you can say it doesn't have enough power for you, and it's SFF, so it's very portable.
    All you'd need to go with it is a TFT screen.
  6. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    The case I have never had a problem with...its the damn 19" monitor that breaks your back. If the case really bothered you they make shoulder straps for both the monitors and cases. You just throw it over your shoulder and head out.
  7. theurgy
    8 Oct 2004
    Ohhh this inspires to make something pretty sweet...
    A Lan Party Dolly that turns into a portable desk....
  8. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    yah unless you goto multiple lan parties or hafta walk an enormous distant, a smaller case wont save that much space/weight and that would be compounded if you had to cut back on performance. Monitors do make the difference and often we bring a wheely office chair to cart them around
  9. Pistol
    Pistol Guest
    Just get a GearGrip from GeekWearz. I bought one at QuakeCon 2002 and I haven't regretted it. Their site is in the final stages of upgrading but when it's up they should have their gear grip plus a monitor grip too. It's adjustable to all sizes (from sff to server tower) and was only $20, I think.
  10. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    meh, I have a chieftec server that is about hip-high on me. I take it to lans. heck sometimes I ride it around at the lan (it has castors) It is just a matter of if you can get everything in the car/van/suv.
  11. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    just do what 90% of the people do:
    get a mid tower case
    about the monitor do what maybe half do:
    get an LCD
