How is an AIO filled with coolant?
Discussion in 'Watercooling' started by antipcw, 6 Dec 2019.
  1. antipcw
    antipcw Minimodder
    11 Jun 2009
    A novice's question.
    Just bought an NZXT Kraken X52 AIO. It is my very first venture into AIO cooling. How is an AIO filled with the coolant? Through which port/hole, or does it already come pre-filled with a coolant?
    I'd rather ask than have an expensive CPU get destroyed. As I am no 'expert' on water-cooling, it's best I ask here from far more knowledgeable folks.
    Thanks for any tips/answers.
  2. RedFlames
    23 Apr 2009
    they come pre-filled and most can't be refilled easily.
  3. antipcw
    antipcw Minimodder
    11 Jun 2009
    Thanks for that. Next question, what or how are they re-filled then when the coolant runs low due to evaporation, etc through the radiator to CPU waterblock path?
  4. RedFlames
    23 Apr 2009
    They typically aren't. The coolants used shouldn't evaporate to any meaningful extent over the life of the cooler [or at the very least it's warranty]...
    They're called 'Closed-loop' coolers for a reason.
  5. antipcw
    antipcw Minimodder
    11 Jun 2009
    Really, really appreciate such a very helpful piece of advice. It's taken a load of worry off my mind. Now, thanks to you, I can relax.
  6. Podge4
    Podge4 Oi, whats your game?
    17 Nov 2009
    I'd been thinking the same, glad I saw this.
  7. David
    7 Apr 2009
    [edit]
    @adidan loves My Little Pony and has a thing for Hello Kitty
    If he likes my post it'll confirm everything I just said.
    :naughty:
    adidan likes this.
