Networks how to check if an email address exists
Discussion in 'Hardware' started by DoNuT, 21 Jul 2006.
  1. DoNuT
    DoNuT What's a Dremel?
    20 Dec 2004
    I was wondering if there's a way to check if an email address already exists or not without sending an email to the address your thinking of. I ask this because I want to send an email to someone that I don't know if I spelled it correct and I don't want to send it to a different person.
  2. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    try sending a blank message or a short message asking if anyones there. if it gets returned as undeliverable then its not 'existant'.
  3. DoNuT
    20 Dec 2004
    thanks, but is there another way without sending an email?
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Knowing if it exists or not won't help, it still doesn't link the address to a name.
    If it's not used, the email'll bounce and you'll get a reply saying that, if it is real it'll go to that address whoever checks it, whether that's the correct person or not.
    Your only way to find out is to send a tester first, and hope the reply is from who you think it should be.
  5. RTT
    RTT #parp
    12 Mar 2001
    You can connect to imap servers and check if a mailbox exists but this is probably out of the question/impractical... and they might not even be using imap.
  6. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    i don't know if your still interested but you could use a program like NeoTrace to do a trace route on the e-mai address and if its there then the e-mail server should respond like if i trace route mine i get
    where as if i trace route a non existant one i get a respone like this
    i hope this helps, you with your problem
  7. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    Even if it does exist you could still be sending it to the wrong person if it's mis-spelled so there's no way of knowing if it's the right person without actually sending them an email.
  8. RickDawson
    RickDawson Minimodder
    29 Mar 2006
    is there an email address stored in the registrant info?
  9. songzila
    songzila What's a Dremel?
    3 Jun 2010
    there are alot of tools available to check if the email add is active.. try automic email hunter
  10. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
  11. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    +1 for this.
    Old school, but I also had this in mind when I saw the thread. Should give you a reasonably definitive answer.
