how to find a free IP address on a network
Discussion in 'Tech Support' started by sotu1, 16 May 2008.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    as the title says, does anyone know how to find an open ip address on a server based network? rather than picking one at random and hoping it's free, is there a better way to do this?
    help muchosly appreciated!
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    dhcp client?
  3. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Advanced IP scanner will let you scan each IP in your B or C subnet (B takes a while), is threaded for multicore processors, and will tell you whether each one responds to ping or not. It'll also give you the netBIOS info for each one.
  4. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    "arp -a" in a cmd shows all ethernet adaptors your machine can see.
    works for me.
  5. Gareth Halfacree
    4 Dec 2007
    Checking the ARP table as per Fod's suggestion is good, but be aware that if you're running a large network with statically-assigned addresses and no management (as opposed to static assignments distributed via a DHCP server) then you're asking for trouble. If a computer is switched off, you won't realise it's got a static IP address - and when it comes back on, it'll conflict with yours if you've chosen the same one.
    I'd recommend putting a DHCP server in place - you can still give each computer a static IP address, but it means that the address will remain reserved even if the PC is off.
  6. Phil
    Phil What's a Dremel?
    19 Jul 2001
    whatever you do, don't purely rely on PING either. Once upon a time at $work, our $isp reallocated our Gateway IP address to another customer...
    we'd set it not to reply to Pings* and so when they pinged the host and got no response, falsely assumed it was a free IP address. Bad move.
    *tbh, blocking ICMP echo request on a piece of networking equipment like a router is a baaad idea.
