how to find the mac number
Discussion in 'Hardware' started by pillow, 27 Nov 2005.
  1. pillow
    pillow What's a Dremel?
    16 Aug 2004
    is there an easy command to be able to find the mac address on wireless cards?
    i have mac security on my wireless network, and my parents have their friends saty here when they come into town, or they have their students work here and of course they bring their laptops and whant to get online. so how can i easily found out a mac address? and will it work for all computer, dells, sony, toshiba, macs?
    thanks
  2. ajack
    ajack rox
    17 Apr 2003
    Do you want to find the mac address of the computer from the computer itself? If so then ipconfig /a (windows) or ifconfig -a (*nix). Or do you mean you want to be able to see which wireless cards are currently connected to an Access Point or router? If the latter, there should be a page on the router config which will show all currently connected devices.
  3. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    If I were you I would just use WPA security instead. All you do is set a password on your wireless router, then to get online you can either tell them the password or put it in for them.
  4. pillow
    16 Aug 2004
    im using wep and a mac filter. to find out out what their mac adddress is for the wireless card, i just type in ipconfig /a?
  5. nimbu
    nimbu Multimodder
    28 Nov 2002
    Drop to a command prompt first, otherwise you wont actually see the read out
    Start-> Run
    CMD <Enter>
    ipconfig /all
    You will get a read out like this
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : Laptop
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Wireless Network Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Dell Wireless 1370 WLAN Mini-PCI Car
    d
    Physical Address. . . . . . . . . : 00-90-4B-D6-4B-2F
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IP Address. . . . . . . . . . . . : 192.168.1.5
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    DHCP Server . . . . . . . . . . . : 192.168.1.1
    DNS Servers . . . . . . . . . . . : 192.168.1.1
    Lease Obtained. . . . . . . . . . : 27 November 2005 09:35:52
    Lease Expires . . . . . . . . . . : 27 November 2005 10:35:52
    The bit I put in bold is what you are looking for.
  6. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    As Nimbu said.
    If you have more than one network adaptor, just look under the description of the network adaptor you want the mac address for.
  7. pillow
    16 Aug 2004
    thanks, i know what numbers im looking for, i just wanted an easier way to do find it.
    thanks
  8. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    If you know the IP address of the machine with the MAC you want to know, and have another machine handy, ping it, then run "arp -a" in a cmd prompt, will list the IP address's you have accessed along with the MAC's for said IP's, just snag it from that list.
    Forsaken.
  9. pillow
    16 Aug 2004
    i think i will just use the comand nimbu told me.
    thanks for the help
  10. Arkuden
    Arkuden mow?
    9 Jul 2004
    or just right click on your network connection and choose status, choose the support tab at the top and then the details button if you are connected or even if you arent you should see the physical address and you dont have to type in commands if you are lazy :p
  11. pillow
    16 Aug 2004
    i would always do it like this, but i dont know how you can get to status when you are not connected, it doesnt let me on the computers/laptops ive seen. ill try this again later since i am truely lazy. thanks
