Features How To Integrate a Pump into a Distro Plate
Discussion in 'Article Discussion' started by bit-tech, 26 Jan 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    Lovely. :D You are running out of subjects to cover.
    Servos for animated parts like vents or doors?
    Nixxie tubes?
    :worried: custom blocks?
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Don't fear, plenty more bits and pieces left under the hood! I guess it will depend on how many areas we dip our toes into, there's an almost bottomless pit of possibilities out there
  4. Fizzl
    Fizzl What's a Dremel?
    9 Jun 2009
    Quick one: do you find integrating the pump like this causes much additional noise/vibration? I've always gone out of my way to decouple the pump from everything else but i go for very quiet builds.
  5. jb0
    jb0 Minimodder
    8 Apr 2012
    "it's not a bat idea to use them as a reference point"
    Quickly, Robin, to the Bat-cave!
  6. Maki role
    9 Jan 2012
    Not with D5s at least, I've not lived with a DDC in a plate though so can't comment much on that, I tend to avoid those pumps for being whiny. I've done a few of the D5 mounted ones now and they all seem fine, I think much of it comes down to how you mount the plate to the case and the materials chosen. If you mounted one in a wood case, I wouldn't be surprised if it makes a real din if not properly isolated.
  7. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    Mr Role, have you covered actually making the o-rings that go into these distro plates? Or anybody here point me in the right direction on how to do it? I have an exciting DDC pump being milled very soon and I'll be needing some o-rings!
  8. Maki role
    9 Jan 2012
    You can actually make them quite simply from stock o-ring cord, all you need to do is superglue the ends together and smooth over any seams.
    edzieba and LePhuronn like this.
  9. LePhuronn
    6 Oct 2016
    Cheers boss. I'm also going to look at getting pre-made and wrapping around the channels. I've at the forethought at least to get my channels within hundredths of a whole millimetre in length, so should be able to get something stock and fit.
  10. DerDings
    DerDings What's a Dremel?
    28 Feb 2019
    It took a while to approve my registration but I wanted to thank you for this awesome guide.
  11. XcoldstarX
    XcoldstarX What's a Dremel?
    8 Oct 2005
    Would it be possible to make a sequential dual pump distribution block with the same material thickness?
    I am trying to work on a design and I realised that for the channel connecting the 2 pumps, there will be a bit of problem designing the screw holes for the channel as such a design will be mechanically unsound, as there isn't a lot of material for the area where the pump impeller cavity is, and adding screw threads over the cavity would mean the acrylic at the screw threads will be less than 2mm thick.
    I would be very grateful if you can provide some pointers to making such a design possible.
    Here's 2 images of my example:
  12. Anfield
    Anfield Multimodder
    15 Jan 2010
    nvm
  13. XcoldstarX
    8 Oct 2005
    This is the area which I would see problems. With the screw thread made, the amount of material between the end of the screw thread and the pump impeller cavity would be like 0.8mm, which may crack under pressure from the pump.
  14. Anfield
    Anfield Multimodder
    15 Jan 2010
    Yeah, 0.8mm def would be too much of a risk.
    You could split up the pumps:
    Thinking loop setup like:
    Pump 1 - Waterblock(s) - Pump 2 - Rad(s) - back to Pump 1
    That way you can feed the outlet from pump 1 into a normal fitting rather than having to navigate the impeller cavity of pump 2.
    Other than that you'd probably be stuck using thicker acrylic (or glue).
  15. XcoldstarX
    8 Oct 2005
    I am going to try your suggestion.
    The pump positions can't change much, maybe they can be spaced further apart by 30mm, but instead of running them sequentially, I am going to try having something in-between, like the radiator at the bottom of the case, so the water channels of both pumps don't interfere with each other.
    I am also trying to do 2 connecting distribution blocks with the connection done GPU block-SLI terminal style.
    This is what I am working on:
  16. Cheapskate
    13 May 2007
    @XcoldstarX - You could lengthen the pump mount screws to run through both plates and do away with the 2nd set of screws. In that configuration, it would probably be better to tap the pump mount bracket and run the screws through from the other side.
Tags: Add Tags
