Cooling How to loop this AMD X2 4200+ 2x 6800GT & chipset
Discussion in 'Hardware' started by Dezjay, 9 Nov 2005.
  1. Dezjay
    Dezjay What's a Dremel?
    10 May 2004
    Hi,
    i working on makeing my AMD X2 4200+ 2 6800Gt's in SLI and the mobo chipset watercooled...
    i have one 120mm rad and one 240mm rad.. what is the best loop according to you guys?
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    I would suggest...
    CPU >> 120 rad >> 6800 GT >> 6800 GT >> 240 rad >> res >> pump >> CPU
    The res and pump could be moved around, but I would suggest keeping them together.
  3. Dezjay
    10 May 2004
    and the chipset with the cpu ?
  4. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    I would suggest you put the GPU's on a separate loop as they are the hotest components.
  5. Dezjay
    10 May 2004
    so take a second pump and use 2 lops
    1x cpu/chipset
    1x vidcards
  6. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    Depending what blocks he is using and what pump, he could easly get away with a single loop.
    i would recon, get a swiftek storm and two maze 4 lps and a d5 pump
    storm, 120.1, maze 4 lp, maze 4 lp, chipsetblock, 120.2 res, pump
  7. Dezjay
    10 May 2004
    its all aquacomputer stuff
    Cuplex XT for cpu (will upgrade to silver)
    Cuplex thingie for chipset( will be upgraded to silver)
    aquagrafx 6800 2x
    res is an aquatube pump is an aquacomputer pump
