Guides How To Make a Flight Case for Your Build
Discussion in 'Article Discussion' started by bit-tech, 18 May 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Not enough moustache shown... :lol:. When the foam slipped into the panels... oooooohhhhh :thumb:
  3. silk186
    silk186 Derp
    1 Dec 2014
    Awesome guide, my cases have taken damage while flying in the past.
  4. Cheapskate
    13 May 2007
    Lovely guide again. :D
    That subtle bit where the first rivet was pulled free by the 2nd. -MDF, everyone. :lol: A good idea there would have been to use some washers on the inside so the rivet head can't pull free.
  5. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Best bet is to use ridged rivets, won’t pull free. Unfortunately I had to use MDF as it was literally the only panel material of the rift thickness I could get in time to make the case before it needed to be used. Won’t have that problem with ply, hexaboard, plastic etc.
  6. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    I'm gonna try my hand at this in time for Sping LAN at NEC. Hey Maki? what do you think the ballpark cost was on the video example?
    J.
  7. Maki role
    9 Jan 2012
    About £150-200 depending on what options you pick generally I’ve found
Tags: Add Tags
