Electronics How to make fans run at 7v?
Discussion in 'Modding' started by talladega, 26 Mar 2009.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    True, but note use a 5V zener (5.1V is usually the nearest stock value) to leave 7V at the fan as required, not the 7V one you've shown, and you've drawn it the wrong way round - banded (pointed) end of a zener goes to V+ supply, or it just drops 0.7V or so.
    The 5W zeners are a bit scarcer than 1.3W but if you can find a handy supplier, go for it.
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    You would need a much bigger diode there to make it work this way. 4x 120mm fans require more then 5 Watts.
    So you're looking for something like NTE5176A / NTE5177A (10 Watts).
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    See post #9
    They're 3W fans @12V = 250mA, drawing approx 146mA @7V, four fans so 583mA flowing through zener, dropping 5.1V = 2.9W; plenty of safety factor left. ;)
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Yeah, was a little bit too fast just counting the initial 3 Watts and not calculating it really :duh:
  5. talladega
    talladega I'm Squidward
    18 Aug 2007
    Ya, I had thought of using a 5w diode but I didn't want to be ordering from so many different sites as in the end it turns out to be more money from shipping so many orders.
  6. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I do realize the diode is backwards, I just used a quick online circuit tester and didn't know how to rotate it. Oops about the wrong rating.
    There are actually quite a few places I found selling 5W 5.1V zener diodes.
