Video How To Plan a Hardline Water-Cooling Loop
Discussion in 'Article Discussion' started by Dogbert666, 11 May 2018.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Hardline tubing requires precision and planning - follow this easy guide to plan your loop properly.
    Guest-56605 likes this.
  2. Guest-56605
    Guest-56605 Guest
    Double barrelled question Alex - Do you personally prefer the flush TT fittings to work with? How do you rate the actual build quality of the TT fittings?
    I also like your one bend in the tubing concept :thumb:
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Personally I think they’re the best rigid compressions on the market atm thanks to that feature. The construction quality is right up there too thankfully, bloody expensive though.
  4. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Another great vid. Bravo!
  5. RedFlames
    23 Apr 2009
    @Maki role needs a monacle... [and the vids need proper subtitles... yes i will keep bringing it up...]
  6. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
  7. Cheapskate
    13 May 2007
    Point? Yeah, that line that popped was tweaked and wasn't a good fit at all. Hard fittings don't work well as GPU support brackets.
Tags: Add Tags
