Software How to print from Photoshop.
Discussion in 'Photography, Art & Design' started by Pookeyhead, 3 Jul 2006.
Thread Status:
Not open for further replies.
  1. Pookeyhead
    30 Jan 2004
    First of all, you need the correct ICC profile for your printer and paper type. These can usually be found on the manufacturer's web site.
    Once you've got your profile, you need to install it. Just put the relevant profile ICC file in c:\\windows\system32\spool\drivers\colour, then reboot your machine (Win XP), If you're a Mac user, I think it's /Users/[your login user name]/Library/ColorSync/Profiles
    Once the icc profile is installed, load your image into Photoshop, and then follow these steps.
    1: Soft proof the image using View/Proof Setup/Custom. Set the profile to your
    printer/paper type. e.g., 2100 archival matte. Set "intent" to perceptual, and have black point comp ON. Simulate paper white should be OFF. See fig.s
    2: Once soft proofed, check and adjust levels/contract/saturation etc. Also,
    make sure the document print size is correct. Whilst this can be set in the
    print dialogue, it's FAR better to make the image the correct size using
    Image/Image Size... BUT... use it as in Fig.0. This will adjust the
    document print size and NOT change the resolution. (Remember to recheck
    "resample image" if you DO ever need to resize an images pixel resolution ).
    Fig 0
    3. Print by using File, Print With Preview. (fig.1)
    FIG.1
    4. The print preview dialog box will appear. Set it as shown in Fig.2.
    FIG.2
    Print size is up to you, but remember that if cropping is critical, around
    96% is best and NOT "Scale to fit media".. (you may have to fart around a
    bit with this) Set the colourspace and profile settings as
    in Fig.2 (using the correct ICC profile for your printer/paper). Click
    "Print".
    5. The print requester should appear (Fig.3). Select your printer, then
    click properties. Do not just click OK.
    FIG.3
    6. After clicking properties, the Printer driver should appear (Fig.4).
    FIG.4
    Your driver may differ from mine slightly, but everything you need
    will be there as it is in the diagram. Re-check paper type. Click on
    "Custom", then click advanced... do not just OK it until you've done the
    next steps.
    7. Once you click advanced, you should see the advanced settings dialog box
    (Fig.5).
    FIG.5
    The most important setting here is "No Colour Adjustment".... make
    sure that's checked. Re-check your paper type, then set your resolution. No
    less than 720, and preferably 1440... If your printer allows 2880 with
    borderless printing, then this will be the best quality, but printing times
    are a nightmare. Make sure "High Speed" is OFF. Click OK to take you back to
    the printer driver, then check your paper and layout settings using the tabs
    (Fig 6).. then press OK... Finally press OK again on the remaining
    Printer Request box. It should now spool, and start to print.
    FIG.6
    If you follow these steps, your prints should be consistently good. Remember, that you should always use the original manufacturer's inks, especially with Epson printers. You CAN get good third party inks, such as Lyson inks, but you need special icc profiles or they will be useless, and even then, they're only really any good on Lyson papers etc. FOr best results, use Epson paper if you have a Epson printer, and only if you have a ICC profile that covers it.
    If you need more help, mail me. My address is in my profile.
    If you wanna use this tutorial elsewhere, please ask... it's just polite - don't pass other's knowledge off as your own, as you just look stupid when someone finds you out. :lol:
Thread Status:
