Windows How to reduce a PDF file size???
Discussion in 'Tech Support' started by neil_b, 14 Jul 2009.
  1. neil_b
    neil_b Minimodder
    20 Jun 2009
    I was sent a PDF of a document, and its 12MB in size and what I really want/need is a smaller version of it that's around 1MB.
    Does anyone know of a that I can use to reduce the size of the file??? I don't want to shell out ££100's of pounds for Adobe Photoshop, and I don't have access to the original pshop files etc.
    Thanks!
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    this might be worth a try; install a free PDF print driver like pdf995 and print the PDF file using that - it may reduce in size as it will reprocess the graphics which are almost definitely causing it to be so big.
    otherwise this will be possible with some ghostscript code-fu, but dont ask me ;P
  3. smajer
    smajer what?!
    5 Jul 2009
  4. darkorb
    darkorb What's a Dremel?
    13 Dec 2009
    You can also try using CutePDF for the same (last time I looked at pdf995 it had ad's all over it). Seems to do a good job creating small PDF's when I've used it.
  5. Jenny_Y8S
    Jenny_Y8S Guest
    Depends on why the original is so big, if it's a PDF made up from one or many scanned images, then reducing it by the size you want may make it look terrible
