Hi all, I have 2x 22" LCDs and wanted to try out unreal tournament 3 over dual monitors to see what it was like. I have a gts 250 and I cant seem to find an option anywhere to make this work. have searched online without any luck. anyone got any ideas? Thanks in advance
*facepalm* We'll im pretty sure there must be a way to adjust the centre of the image to not be behind the bezel. Like 40% one side and 60% the other.
There is no way to do it unless you find a UT3 mod. For what it's worth, AMD/ATI are currently talking to game developers to standardise a method of offsetting the cursor, so their Eyefinity 6 screen setup will work with FPS games. Don't expect it any time soon though.
i remember i did it back in UT'99. simply ran it in windowed mode and stretch it. but of course, image was stretched and it's really ugly. to avoid stretching, try set your custom resolution and then run in windowed mode.
Another option would be Soft Triple Head. If you tell it there is no third monitor, it'll do; That's over two 24" monitors.
