Storage How to tansfer laptop HDD to laptop SSD?
Discussion in 'Hardware' started by l3v1ck, 30 Sep 2010.
  1. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Okay, I'm thinging of switching my laptop HDD out for an SSD when the warrenty expries.
    I've yet to find out whether it's a 1.8" or 2.5" drive, but that isn't my issue.
    As the laptop came from Sony, it didn't come with a Windows CD for a fresh install, there's just a hidden 100MB recovery partition on the drive. There's only room for one drive in the laptop.
    So my plan is to clone the HDD to the SSD and then just switch them out. The question is how do I do that? Can you buy USB caddies for 1.8 or 2.5" drives. If so I can just use Acronis True Image.
    But if caddies that size aren't available, how can I do it.
  2. Mongwopman
    Mongwopman King Ding-a-ling!
    28 Sep 2010
    I'd just try clone it with Acronis.
  3. Tangster
    23 May 2009
    1.8" HDD Caddy
    2.5" HDD Caddy
    Just google it, these were the 1st that came up.
    Also if you have a desktop, you can connect them both up via standard sata cables and clone that way.
  4. adam_bagpuss
    24 Apr 2009
    just back it up to an external drive
    restore it to SSD when you install it.
    job done
  5. l3v1ck
    23 Apr 2009
    Thanks everyone. Nice to know I can just use standard software and a caddy.
  6. Dudey109
    Dudey109 Minimodder
    20 May 2010
  7. kenco_uk
    28 Nov 2003
    I use Acronis True Workstation Echo software each time I need to clone. It's worked every time so far, In Vista and XP. You need the source and target drives both plugged in though, it doesn't back up to an image file, it literally does an on the fly copy. It resizes the partitions on the new HDD too, if the new HDD is larger. It takes a while though, the old drive (200GB) connected to an internal pata and the new drive (500GB) connected using a usb caddy on a PC I did last night took about 3.5 hours to do. There was a total of about 55GB of data across three partitions.
    I also use Image4Dos at work, which does the trick quite well. Norton Ghost works really well, too. The Acronis software is dead easy though.
  8. l3v1ck
    23 Apr 2009
    That's fine. As long as can just plug the SSD in once the copying has been done, and it boots, I'm happy.
