Windows how to view only files within subfolders?
Discussion in 'Software' started by sotu1, 3 Jan 2014.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Hi guys,
    So turns out Apple has made a bit of a mess of all my photos and I want to manually sort them out.
    I have thousands of photos in different folders and I wanted to sift through them all to tidy them up.
    My question is:
    Is there a way to view only the files within a collection of folders, all at once??
    Either in Windows or Apple iOS
    Cheers!
  2. wolfticket
    19 Apr 2008
    The search function in Windows (or iOS I'd imagine) should do that unless I'm missing something.
    Simply search *.* ( or kind:=picture in Windows for just pictures) within the photos folder.
  3. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    hmm good thinking. Am worried I'll miss out random files though :S
  4. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Do you want them to stay in the folders? If not I'd be tempted by a bit of batch file / powershell action to move them all in to one root folder.
  5. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    I'm not entirely sure what you are trying to do but if, say, you have a directory called "photos" which itself contains folders of photos, you can list them all with a simple dir command:
    dir *.jpg /s /b
    you can send the results to a txt file:
    dir *.jpg /s /b > c:\photos.txt
  6. alecamused
    alecamused Minimodder
    22 Apr 2008
    Open a terminal window (command + space, type terminal).
    Create a target directory (mkdir </path/to/target> )
    Navigate to the top level directory you want to search through (cd </path/of/directory/>)
    Type "find . -type f -exec mv {} </path/to/target> \;"
    (recursively finds every regular file and moves it to your target directory)
