Portable HTC One M7 USB Host Mode Issue
Discussion in 'Tech Support' started by ModSquid, 3 Oct 2014.
  1. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Morning all!
    Funny one this, but thankfully only requires a simple description. Having had the Android 4.4.2 update recently pushed out (rather late) to my handset, within a couple of weeks any attempt to connect the charger now results in the notification that "Handset cannot charge whilst in USB host mode" and nothing happens.
    The only way it will now charge is by turning it off completely, disabling fast boot and watching it try to cycle its way through on/off/charge modes whilst taking the whole night to trickle its way up to 99%, where it stops.
    If fast boot is on, it just won't charge at all. Have searched the web and also tried the htc-recommended "hold vol up, vol down and power buttons for two mins to reset charging meter" solution but that didn't work either. Factory reset no good, can't roll Android back and can't reinstall the system update pack still on the phone as it isn't recognised.
    Any help gratefully appreciated as next step is to return for repair, which I really don't want to have to do unless absolutely necessary!
    Cheers guys...
  2. ModSquid
    16 Apr 2011
    Still no joy and I'm getting mad. Any suggestions?
  3. Tichinde
    Tichinde Minimodder
    1 Sep 2010
    Seems to imply the 2 minute reset worked.
    http://forum.xda-developers.com/showthread.php?t=2481211
    Also a safe mode boot into the OS is suggested on that thread.
    Failing that, other sources suggest using the original cables (some have an extra pin apparently for setting host mode) and making sure the connections in the phone are clean.
    Not having the phone myself, that's the best I can suggest really...
