Hi guys, Just wanted your opinions on what you thought about these two cases for a HTPC, i'm thinking of building one and wanted you input before buying a case. The first one is: http://www.cclonline.com/product-info.asp?product_id=43704&tid=frooct I like this case, but dont really know if i will be able to pull it off in such a small case as i'm not that use to small form hardware. The second is: http://www.xcase.co.uk/X-Case-ITX-Atomic-Cube-p/case-x-case-atomic-cube-red.htm I like this one but it is a bit big. So what do you guys think? Thanks AC
The picture on the first one doesn't give too much away. At first glance it looked ok, but the second one looks nicer as stock. I guess it depends if you're modding it too.
http://www.scan.co.uk/Products/Silv...nt-Panel-SECC-Body-Black-with-300W-80plus-PSU id get this one ^^
