Case Mod - In Progress HTPC , mini ITX water cooling
Discussion in 'Project Logs' started by ArtX38, 1 Jul 2012.
  1. ArtX38
    ArtX38 What's a Dremel?
    23 Jun 2012
    Project Name “Silver spiders”
    PC Components :
    Case - Thermaltake DH 202
    Power Supply - Thermaltake TR2 RX 550W
    Motherboard - ASUS F1A75-I DELUXE
    Processors - AMD A8-3870K APU
    Memory - Corsair Vengeance Black 8GB
    Video Card - Asus Radeon HD 7850
    SSD OCZ Agility 3 SATA III
    Water Cooling Component: :
    Koolance GPU-220 (Vid/MB)
    Koolance CPU-370 (CPU)
    Koolance CHC-125 (MB)
    Koolance MVR-40 (MB VReg)
    Koolance RP-401X2 Single 5.25" Reservoir
    Koolance Water Pump PMP-400 High-flow Pump
    Koolance Radiator, 1x120mm 20-FPI Copper
    Koolance Radiator, 2x120mm 20-FPI Copper
    Koolance RAM-33 X 2 (Single DDR/DDR2/DDR3/SD)
    Koolance Video RAM Heat Sinks EOL
    Koolance Liquid Coolant
    Others components :
    Lamptron Fan Controller FC5V2
    Fan – 3 x Scythe Gentle Typhoon 120mm 1850rpm
    10 x WD Elements Desktop 2TB USB2.0
    Logitech diNovo Mini™
    Logitech Harmony® 300i Remote
    Insert water block to motherboard:
    Prewiew:
    The finish my HTPC media center:
    Logitech diNovo Mini™, Logitech Harmony® 300i Remote
    11x WD ELEMENTS DESKTOP 2TB, 10x LogiLink USB 2.0 HUB
  2. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    cool project!
    so You decide to LC mosfets and bridge? any temps? fanspeed?
    I heard that koolance rads pretty dens = highspeed fans preferred.
    just noticed: RAM under water??? i'm confused...
