Overclocking [hwbot] Super Pi 1M Rankings!
Discussion in 'Hardware' started by Eliminos, 17 Feb 2006.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Damn you and having shiny toys to play with!
    Nice work with the Yonah though, hopefully you wont be holding the top spot for too long :naughty: :naughty: :p :p
  2. Hazza
    Hazza What's a Dremel?
    25 Nov 2003
    [hwbot] Hazza - 33.406 - A64 3500+@2.61GHz / 2*512MB Ballistix PC4000 @237MHz 2.5-4-4-10[/hwbot]
    Only a slight improvement but I think I can get more with this new ram.
    A long way off 19.703s though ... :sigh:
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Hazza, tried a 10x multi, and 1:1 with the ram? That should work better.
  4. Hazza
    25 Nov 2003
    Im running my ram at 1:1 but it just isn't stable past 240MHz (no idea why), so I can't make much progress on a 10x multi without running a divider :miffed:
  5. Shadowed_fury
    21 Nov 2003
    Odd, my old 1gb setup of ballistix would do near 280mhz :/
    Looking at your timings, yours should be fine. Just 2.7/8v?
  6. Hazza
    25 Nov 2003
    yep, even at 2.85V, it won't post at 250x9 :miffed:
  7. Shadowed_fury
    21 Nov 2003
    Sounds like it could be a bad set, but it won't be the usual 2gb kit thing, since its a different chip.
    I think your just unlucky, however you should send them back since they aren't even making the 250mhz they're quoted for. :)
  8. webchimp
    webchimp What's a Dremel?
    9 Oct 2002
    Intel Pentium D 805:
    [hwbot]webchimp - 29.87 - Intel Pentium 4 D 805 @ 4400mhz - 220FSB x 20 - Watercooling[/hwbot]
    As I mentioned in another thread, I managed to boot into Windows at 4500Mhz, but the system wasn't stable enough to run Super Pi and this was the best result I managed.
  9. huren
    huren What's a Dremel?
    14 Aug 2004
    ** invalid **
  10. Shadowed_fury
    21 Nov 2003
    Woah, guys guys read the first page.
    You need to use the hwbot tags for these to even show up in the Score board.
  11. huren
    14 Aug 2004
    am i not doing it correctly now D:!
    edit: eek fixed
  12. Shadowed_fury
    21 Nov 2003
    Thats right huren. Check the table now :)
  13. Pookeyhead
    30 Jan 2004
    although that's not a valid screenshot!
  14. Shadowed_fury
    21 Nov 2003
    Hmm, you have a point ;)
  15. ArsoN
    ArsoN What's a Dremel?
    30 Sep 2003
    [hwbot]ArsoN - 33.099 seconds - 3200+ Venice@ 2.7GHz, OCZ Value PC3200[/hwbot]
    I guess I probably kinda cheated, it wasn't rock stable, crashed after ~15minutes of Pi to 32m places. I had to use a huge voltage to get that speed aswell. :(
    I want a decent CPU. :( I have just as much problem OCing my GFX cards dammit, though half of that is probably due to heat.
  16. Shadowed_fury
    21 Nov 2003
    I don't call it cheating! If you can get the PI in and screenshot it. Your done ;)
  17. huren
    14 Aug 2004
    Argh werd at not being valid.
    ***huren waits for his system to come back from review.....
  18. huren
    14 Aug 2004
    [hwbot]huren - 29.82 - FX60 @ 2.99 - 230FSB x 13 - Watercooling[/hwbot]
    ok valid screenshot time then :p
    I just got my system back, and chucked in the new fx60, playnig around with some timmings etc, this was first not so good run.
    **edit** am i doing this hwbot thing wrong, im so simple it hurts >_< **
  19. Highland3r
    25 Jul 2003
    Have had better scores, but the chips gone now and didnt grab a screeny of them.
  20. webchimp
    9 Oct 2002
    Flip you mellon farmer, you've knocked me down to 13th place! :waah:
    Only scores over 30 seconds from now on please. :D
