Graphics Hybrid physx
Discussion in 'Hardware' started by voids sleet, 10 Nov 2012.
  1. voids sleet
    voids sleet What's a Dremel?
    3 Sep 2009
    hello bit tech forums
    been lurking about for a bit to long at the moment
    right i am looking into Hybrid physx, i currently have 2 7950's in my rig
    now the thing is i have a gt 610 sat here, which has half the cuda cores of a gt 9800 but its clocked a little higher
    is it even worth considering putting it into the rig for this or is it even worth doing the Hybrid physx with a different card all togeather?
  2. rollo
    rollo Modder
    16 May 2008
    Hybrid physics is pretty broken and not many people ever seem to get it working.
    General oppinion seems to be if you want physics buy nvidia.
  3. voids sleet
    3 Sep 2009
    ok fair point :thumb:
    ill lob this 610 at someones face, thanks for the replay
  4. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    Depending on your CPU (I wouldn't run it on a Q6600 if that's what you are still using) you can run PhysX on the CPU. I did it in Borderlands 2 with my i7 950 and it performed reasonably well.
  5. voids sleet
    3 Sep 2009
    ah yes i need to update my sig, now running on a i7-3820, crossfire 7850's, enough ram to last and got a nice little asus xonar sound card there also
    ill give that a go see what happens
  6. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    Yeah with Xfire 7 series GPUs I didn't think you'd still be using a Q6600 :p.
    You should be good with a 3820, but it still wont be as good as a GPU.
  7. majnu
    majnu What's a Dremel?
    13 Nov 2012
    Don't some games like Borderlands 2 do PhysX via the CPU for AMD users? Since very few games use it, I personally wouldn't add another card in your system, due to the increase in noise, heat and PSU strain it will give.
