Case Mod - Complete ⭐ HYDRA BENCH CARNAGE
Discussion in 'Project Logs' started by warboy, 12 Jan 2019.
  1. warboy
    warboy Insane modder
    24 Nov 2011
    New Year start with a new case mod ;)
    For this PC I will be inspired by Carnage the comics character ...
    The Hardware specs:
    Case:
    Hydra Bench Deluxe
    Motherboard: X299 AORUS GAMING 3
    CPU: Intel Core i5-7640X
    VGA: GTX 1070
    RAM: 32GB S3+ DIMM DDR4 2400MHz C17 (4x8 Gb)
    POWER SUPPLY: Sharkoon Silent Storm Cool Zero <====NEW ENTRY :clap::clap:
    SSD: XPG GAMMIX S10 PCIe Gen3x4 M.2 2280
    SSD: S3 PLUS TECHNOLOGIES 480 GB SSD X2
    Mouse: Sharkoon SHARK Force <=====NEW ENTRY :clap::clap:
    KeyBoard: Sharkoon SKILLER MECH SGK3 <====New Entry:clap::clap:
    Watercooling:
    Radiator fans: 2x Thermaltake Riing 12 RGB Radiator Fan TT Premium Edition 5 Pack
    updating soon
    Here are some details of the Hydra Bench Deluxe
    SHNS0 likes this.
  2. warboy
    24 Nov 2011
  3. warboy
    24 Nov 2011
    after I changed the color and add the glue.
    arduum likes this.
  4. warboy
    24 Nov 2011
    I designed and printed a support for the fan RGB controllers
  5. warboy
    24 Nov 2011
    then I printed the head of carnage;)
    and add some of color :)
  6. warboy
    24 Nov 2011
    afterwards I designed the cover for the tank, and now i print with 3d printer.
    after I revive it and with the glue I will add the symbiote that will take control of the PC;)
    neSSa likes this.
  7. Cheapskate
    13 May 2007
    Reservoir cover?
    warboy likes this.
  8. warboy
    24 Nov 2011
    YESSS:clap:
  9. warboy
    24 Nov 2011
    while I finish printing the cover of the tank, I install the Sharkoon Silent Storm Cool Zero power supply, the Alphacool VPP655 PWM pump with the plexig top, and the support for the RGB fan controllers.
  10. warboy
    24 Nov 2011
    This is the support for ssd (480 gb S3 Plus Technologies)
  11. warboy
    24 Nov 2011
    After I print the top plate, and I add the glue for "simbiote effect".
    This is a 3d part for the waterblock ;)
  12. warboy
    24 Nov 2011
  13. warboy
    24 Nov 2011
  14. warboy
    24 Nov 2011
  15. Cheapskate
    13 May 2007
    I love your work, but this one isn't grabbing me. :(
    I think it's the way the goop patterns are acting like camouflage.
    warboy likes this.
  16. warboy
    24 Nov 2011
    Thank you for your sincerity;)
  17. warboy
    24 Nov 2011
  18. SharkGTX
    SharkGTX What's a Dremel?
    23 Mar 2019
    another Hydra))))
    Nice)
    warboy likes this.
  19. warboy
    24 Nov 2011
