News HyperX demos new keyboard, headsets, and DDR4 memory
Discussion in 'Article Discussion' started by bit-tech, 3 Jun 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. loftie
    loftie Multimodder
    14 Feb 2009
    I grabbed the Hyper X Alpha when my Cloud cable got snagged and must have loosened the mic cable. In all honesty, I thought it was less comfortable than the original cloud - though I prefer the cloth cups which the alpha doesn't have, sounded about the same and the detachable cable, while fitting snugly, didn't actually make contact well. The slightest movement would disconnect the mic even though the cable was in and didn't appear to have moved.
    I returned it the next day and got a Cloud 2, and TBH, I don't see the point of USB headsets. The 7.1 stuff is mediocre, and it gobbles yet another USB port. The soundcard on the Cloud 2 also seems to cut audio off if it thinks it's too quiet, which the mic output is pretty low. So if you talk quietly I imagine it's not gonna pick you up. I'd much rather use 3.5mm jacks connected to my front audio ports.
    One plus side to the USB one, it has barely, if any, noise, which the analogue one in my case did have.
  3. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    I had a Plantronics headset that did '7.1' surround and it was astoundingly brilliant. The first few weeks I kept taking it off thinking I'd left the speakers turned on at the same time as the headset. I used it until the thing was held together with duct tape and I still miss it now. Think it was the Gamecom 777.
    For some reason no other surround sound headset worked as well as that one, even new Plantronics models. At least it gave me an excuse to buy some Sony MDRs...
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    So... The Orbit S seems to be a rebranded Audeze Mobius. I have the originals and damn, they're good.
    Btw, I think you have a typo in the article: who is Azuze? Given there's even an Audeze logo on the headphones, I'd wager they make the planar magnetic drivers.
  5. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Thanks! Think part of this was typed bleary-eyed and gin-soaked on a plane :worried:
  6. perplekks45
    9 May 2004
    A good flight, I take it?
  7. Dogbert666
    17 Jan 2010
    Could certainly have been worse!
    perplekks45 likes this.
Tags: Add Tags
