Guide I Built a Lens
Discussion in 'Photography, Art & Design' started by veato, 24 Feb 2016.
  1. veato
    veato I should be working
    15 Jan 2010
    I know some like to mod PC cases around here but how about modding a lens?
    I decided to butcher an old 28mm manual lens I had lying around and turn it into a tilt/shift style lens. It was pretty successful so I blogged about my exploits here: http://planet-veato.blogspot.co.uk/2016/02/building-tiltshift-lens.html
    Have a read if you fancy having a go.
    I do have some slight regret as the lens I chose was actually in very very good condition and a good sharp lens at that! I would advise picking something cheap up from eBay if you fancy it yourself.
  2. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
    Not the same level of mod but I converted a Tessar 50mm with a faulty A-M Mechanism into a full time manual lens.
    It's been working fine for the past 3 years.
  3. Pliqu3011
    Pliqu3011 all flowers in time bend towards the sun
    8 Aug 2009
    Great thread idea!
    I also "modded" a few lenses.
    I think I also posted about this one in the latest purchases thread:
    A Konica Hexanon 45mm f/1.8, the fixed lens of a Konica Auto S2, adapted to Fuji X mount using step-up rings and a reverse adapter.
    Separate focusing helicoids with a screw mount are really expensive (even the Chinese ones), so I reuse the helicoid of a crappy Izumanon macro diopter to adapt several lenses without helicoid to my Fuji X-E1.
    The base is the X-mount part of a set of macro tubes. I actually didn't plan for this but when I received the tubes I noticed the segments connect using a 52x0.75 screwmount, just like a 52mm filter, which is super convenient.
    On the right a specialized large format Steinheil 56mm f/1.9 macro lens of an oscillograph (completely rubbish for normal usage but very high resolution at high magnifications) which I gave a 67mm screw mount using a Canon EOS to M42 adapter I had lying around and a 55mm-67mm step-up ring.
    Together a high quality macro lens (though a bit clumsy in operation, and terrible with flaring):
    The rings which used to hold single lens elements of the macro diopter can be screwed out and have a ridge which I simply tape my projector lenses to. Here for example my Leitz Wetzlar Elmaron 80mm f/2.8 (super soft but flattering for portraits).
    No aperture of course, but lots of fun to use.
    I'm also planning on making something similar to veato's tilt-shift lens with the medium format Schneider-Kreuznach Radionar 105mm f/4.5 I took from an old bellows camera. It has a wide enough image circle (at least 9x9cm) to allow for a lot of tilt and shift.
    Right now I'm working on modifying the broken auto aperture mechanism of an otherwise beautiful Rollei Planar 50mm f/1.8 to a normal, sane design. I have no idea why the makers of this lens went for such a stupid, fragile construction instead of using what works perfectly in 99% of other lenses.
