I come asking questions, yet again...
Discussion in 'bit-tech Folding Team' started by mikemaher205, 18 Apr 2013.
  1. mikemaher205
    mikemaher205 What's a Dremel?
    14 Aug 2011
    Edit: To save re-posting...
    I've upgraded my Intel Core i5-2500K to an i5-3570K.
    The client recognises this and system is stable. Do I need to delete and re-make the slot to ensure full function and folding success or will it be just fine?
  2. RedFlames
    23 Apr 2009
    i've had slots go AWOL too... thought it was just me... might be worth checking the official forums...
    as for ppd on a 285 honestly can't say... not folded on a 200 series card with 7.3
  3. mikemaher205
    14 Aug 2011
    A new problem... Having two different GPUs has now caused my GTX 660 to not do anything and it's slot appears to be folding under the GTX 285... What do I need to configure in the slots to make the 2 GPUs run separately and in harmony?
  4. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    In older clients you couldn't mix generations of cards well, I would drop the 285 for now whilst someone with more experience comes along and confirms/denies this.
  5. mikemaher205
    14 Aug 2011
    OK, will follow that advice for now, thanks.
    Any guesses why the CPU slot is deleting itself? It's happened again...
  6. mikemaher205
    14 Aug 2011
    Changed the question now... :)
  7. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    You shouldn't need to make any changes - it should just detect the new CPU and off it goes.
