Equipment I gots a 35mm :)
Discussion in 'Photography, Art & Design' started by sotu1, 4 Oct 2013.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    For my Nikon D3200. Hopefully have something to show by the time the weekend ends :D
  2. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Awesome stuff! I love using the 50mm on my D3 (roughly equivalent field of view). 90% of my photos are done with it these days.
  3. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Right, so my pictures seem to have turned out pretty crap (blame alcohol at wedding and using my SLR as a happy snap cam.....)
    but will try and get some pics posted tongiht
  4. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    If it's your first prime, they take a bit to get used to. You'll become a better photographer for it though. I'm almost exclusively primes now, even though I have a 70-200 f/2.8 sitting there.
  5. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Primes are a lot of fun to shoot and I'd even say once you get used to the field of view, it's a lot faster as well.
    I've not touched my DSLR kit for ages, the x100 gets taken with me everywhere.
  6. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    It's my second prime, I have a 50mm which I love but it's just a bit too close 50% of the time, which makes it awkward for indoor shooting as no space to move back. Was hoping the 35mm would fix that and it does.
    However, I found it's not as sharp as the 50mm, nor did it manage to auto-focus as well on what I wanted it to focus on. Maybe it was me, but I found myself constantly having to jump to manual - which I don't like doing because my eyesight is crap and looking through the viewfinder I can't tell the difference between blurry and sharp.
  7. Chr!s
    Chr!s What's a Dremel?
    21 Apr 2004
    Are you using it wide open? The Nikon 35mm is best around 2.8 and above for sharpness, wide open your D3200 may struggle to focus due to the very shallow dof as well.
  8. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    On the night of the wedding I left it on full auto/no flash, mostly because I don't have the time to fiddle with settings.
  9. Chr!s
    21 Apr 2004
    It probably did try and shoot wide open then, try setting on aperture priority at 2.8 and see if the results are any better.
  10. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Will try that. I imagine in the low light of then party it was trying to open up fully.
  11. Lance
    Lance Ender of discussions.
    6 May 2010
    The sooner you move away from Auto the better in my opinion. There are times when its handy, but really you want to be shooting on A (aperture proiorty) and change your ISO and Aperture to suit. Otherwise you might as well have bought a mirrorless camera or even a good hybrid.
    You know you have that "programmable button" just under the flash option button? Its currently set to "timer". If you reprogram that to ISO you can change your ISO on the fly which will make life much easier for you.
    Personally I then have my aperture mode set to 1 stop down because I like the shadows to still be there. Have a go at shooting like this and you might find you get slightly better pictures. Well in all honesty for me I started of taking far worse pictures, and I've gradually improved, to the point where I am beginning to understand more of why and where my pictures can be improved, and why the pictures that go into the "photo of the day" section look so good.
    *Just to point out, I don't mean NEVER use auto, it does have its uses and can take a good photo, but you need to learn its strong and weak moments and why that is.
  12. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Yeah, I know where you're coming from. I spend more time in P/A modes now, but the advice I was given for weddings was to stick to Auto and play it safe; it's not a re-creatable situation.
  13. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    THAT, 100%. I had my D5000 set up the same way. Now I'm on the D3, I have a dedicated button for it (and pretty much everything else!) :D
  14. October
    October Mariachi Style
    20 Jul 2009
    Two edged sword that, if auto doesn't give you results you're happy with.
